Results 1 to 3 of 3
Thread: Rigid Tapping
    Mar 2012
    New Zealand
    Rigid Tapping
    Hi My name is Stu and I am from NZ
    I am programming on NX8 and machining on a Mori Seiki NV5000
    I am trying to do some rigid tapping and after programming and posting all I get on the machine is the spindle doing 1 rev and pitching 10mm
    Can any one help?
    The code is as follows
    O0001
    (PART: MoriSeiki_Master.prt)
    (FILENAME: plate3.ptp)
    (Tue Mar 13 15:15:09 2012)
    (MACHINE: Fanuc Control - Mori Seiki V3.0)
    (Added Helical Output)
    (Post by Trihedral Solutions Ltd)
    (TOOL: UGT0371_005 )
    (INFO: Operation : TAPPING - Point to Point)
    (INFO: Spindle : 50 RPM Minimum Z: -10.000 Time: 5.61 Mins)
    (INFO: Feed Rate : 50.00)
    (INFO: Tool Minimum Z: -10.000 Time: 5.61 Mins)
    (TIME: Total time for job: 5.61 Mins)
    G40 G17 G49 G94 G80 G90
    (BEGIN: TAPPING)
    G00 G91 G28 Z0.0
    G90 G53 X-800. Y0.0
    N0001 T01
    M06
    G90 G54
    X64.7 Y-109. S50 M03
    G43 Z10. H01 M08
    G95
    S50 M29
    G84 X64.7 Y-109. Z-10. R3. F50.
    S50
    X13.7
    S50
    Feb 2009
    Your in Inches/MM per revolution. So, 50.mm per turn of the spindle. had the same problem running metric taps on Mastercam. Change your feedrate to match, or switch to G94.
    Mar 2012
    New Zealand
    thanks for that.
    that is interesting as I set the feed rate in the CAM prog as 0.8mm per rev not 50mm/rev.
    I will give it another try and report back.
  1. Replies: 13
    Last Post: 07-03-2009, 07:43 PM
  2. Rigid tapping
    By Ken_Shea in forum General Metalwork Discussion
    Last Post: 12-20-2008, 12:35 PM
  3. What exactly is Rigid tapping? Why people always ask does it do rigid tapping?
    By cjchands in forum General Metalwork Discussion
    Last Post: 12-19-2008, 09:19 AM
  4. Tapping head or rigid tapping
    By Gregory_C in forum Syil Products
    Last Post: 10-18-2008, 01:49 AM
  5. Rigid tapping or tapping head
    By wildcat in forum Industrial Hobbies (Support forum)
    Last Post: 09-24-2006, 01:08 PM
