Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 01-31-2012, 09:53 AM
jan.van.gent is on a distinguished road
NX 7.5 question about cpu and ram usage
Hallo,
I wonder if it's possible to change some settings of NX in order it would use the computer full RAM/CPU power instead of only about 20% during calculation of tool paths etc.
Is this possible or is there another limiting factor?
Best regards,
Jan - cadcamforum.be
Old 02-01-2012, 11:18 AM
camster is on a distinguished road
You can generate tool paths in the background to take advantage of multiple CPUs
NX CAM is not a multi-threaded application
Old 02-06-2012, 03:05 PM
markrief is on a distinguished road
NX CAM will use all of the available resources of the core it's running on.
For example, on my quad core machine, If I generate an operation it uses all of the core I am on, which shows as 25% in the task manager.
To use other cores, use Parallel Generate instead of Generate. For example, if I Parallel Generate 4 operations, I will see 4 processes in the task manager processes tab, each at 25%. On the Performance tab, CPU usage is at 100%.
If you are not seeing this, then you may have another bottleneck.
ID:	152074   Click image for larger version
Mark Rief
Siemens PLM
plc usage ceencee General Electronics Discussion 3 07-19-2011 10:38 PM
Newbie- Newbie Question about Insert Usage jeremyray25 General Metal Working Machines 6 10-24-2009 08:14 AM
what's this and usage praest Europe Club House 6 10-07-2008 12:42 PM
G210 usage bubbax1 Gecko Drives 3 05-18-2008 04:56 PM
PIC possible usage? blackbeard52 PIC Programing / Design 7 01-28-2008 07:43 PM
