| UG NX UG CAD/CAM Discussion |
We use both ProE and UG based on the customer. My question is when using UG NX6 sketch is there a way to have the dimension from the centerline equal the diameter when sketching? The way I am do it now is creating a radius but not the diameter. I ProE I select the sketch curve the centerline I created while in that sketch and then the sketch curve again to get my diameter dimension. attached are screen shots to help illustrate. Thank You |
a sketch is not a drawing so why change radius to diameter? . in Solidworks it is usually on right click menu. . i would normally say check the help system but i use NX5 and rarely does help answer many questions. . i was printing the help files on manufacturing and i was getting past 500 pages. i had a simple question in program operations menu if operation is blue text instead of black test what does it mean? i searched program operations blue text but of course nothing came up explaining what i was looking for. |
when sketching i believe in NX5 at top menu Insert then dimension then you can select type of dimension radius or diameter (don't just use inferred dimension so you choose which type). . i am not sure how to change once dimension is already there. many items can be changed by selecting then in right click menu their are things that can be changed. . . blue text in manufacturing operations menu means a tool change is needed. i had multiple operations and wondered why some were in blue text and others in black text. i am not sure where it is set as on a another computer all the text was black. thats the trouble with a custom setup and then using another computer with a default installation |
| Attached is a zip .avi file that is showing how I do a sketch diameter in ProE sketch and hoping illustates better what I am looking to do in UG in sketcher mode. Which is to create a diameter dimension for a cross section of a revolved sketch. |
| Unigraphics Extrude / sketcher | greenchair | General CAD Discussion | 4 | 01-05-2009 09:10 AM |
