| UG NX UG CAD/CAM Discussion |
Hi, At our facility we have a Sauer ultrasonic 70-5 5-axis milling centre. It's the same as the DMG 70-5, but it is also capable of ultrasonic milling. I'm having troubles making a postprocessor. I'm using the NX postbuilder. The Sauer uses heidenhain software.
Line 7380 is causing trouble, what can i do about it? Any tips? |
Hi, Maybe i should give some more information. I'm using NX 7.5 software with the NX postbuilder. Its for the DMG 70-evo with heidenhain iTNC530 control. A part of code: 0130 M129 0140 Z+400.000 B+.000 C+.000 FMAX M91 0150 L M128 0160 L X-22.315 Y+16.071 FMAX M3 0170 L Z+13.000 0180 L Z+3.000 FMAX 0190 L X-22.315 Y+16.071 Z+.000 B+.000 C+.000 F250. M8 0200 L X-15.747 Y+16.071 Z+.000 B+.000 C+.000 F250. 0210 L X+15.747 Y+16.071 Z+.000 B+.000 C+.000 F250. 0220 L X+22.315 Y+16.071 Z+.000 B+.000 C+.000 F250. 0230 L X+22.315 Y+16.071 Z+3.000 B+.000 C+.000 F250. 0240 L Z+13.000 FMAX 0250 L X-25.754 Y+9.643 FMAX .... 9000 L X+49.277 Z-8.815 FMAX 9010 L Z+3.661 FMAX 9020 M129 9030 Z+200.000 B+.000 C+.000 M91 9040 C-172.799 9050 L M128 9060 L X+11.531 Z+3.661 FMAX 9070 L Z-20.392 FMAX 9080 L X+15.490 Y+50.931 Z-24.352 B+.000 C-172.799 F1517. 9090 L X+8.574 Y+50.931 Z-24.352 B+.000 C-172.799 F1685. 9100 L X+.000 Y+50.931 Z-24.352 B+.000 C-172.799 F1685. 9110 L X+.000 Y+50.053 Z-24.352 B+.000 C-172.799 F1685. 9120 L X+8.574 Y+50.053 Z-24.352 B+.000 C-172.799 F1685. 9130 L X+13.079 Y+50.053 Z-24.352 B+.000 C-172.799 F1685. 9140 L X+13.079 Y+50.053 Z-17.352 B+.000 C-172.799 F1685. 9150 L Z-10.352 FMAX 9160 L Z+3.661 FMAX 9170 M129 9180 Z+200.000 C+.000 M91 9190 B+22.140 C-172.123 9200 L M128 9210 L X+53.597 Z+3.661 FMAX 9220 L Z-3.517 FMAX 9230 L X+57.364 Z-17.001 FMAX 9240 L X+54.614 Y+50.053 Z-21.879 B+22.140 C-172.123 F1517. 9250 L X+54.644 Y+50.053 Z-21.871 B+22.170 C-172.112 F1685. ... You clearly see the problem... Some lines don't have the L in front. The home position is set up at x+200 y:0 z:0 b:0 c:0 so I guess the problem is with the coming home block. But when I check this in the post builder: ![]() The L is present so it should generate code with L in front i guess. When I delete the lines with M91 and the line without L in front (just remove them manualy) the NC code run just fine. But if I make a 5-axis program and post process it, 100+ of these lines are present and it's stupid to delete all those lines manually. Anone has an idea what to do about this? |
| Unfortunately I only have my mac available which doesn't run postbuilder NX8. And I already opened my heidenhain post with NX8... For quick and dirty solutions, just to not be held up with 1 problem to solve another, I would put a text box with "L" in front. I do remember having a similar problem, but I don't remember how I solved it. Well, not with a literal "L". Maybe there is a relation with the M129, that doesn't have an L in front while the M128 afterwards does have an "L"...... You know, I think it is in the L definition, that is under "WORD", G_motion. I guess it is set to modal. Change it to non modal. Pretty sure that's it. Are you going to the Siemens NX8 CAM event, 25th januari? Only 's Hertogenbosch, AFAIK. |
| Need Help!- postprocessor TNC 355 | ccosma | EdgeCam | 0 | 06-12-2010 09:51 AM |
| What is a Postprocessor | pofo | General CAM Discussion | 5 | 12-11-2009 07:43 AM |
| Newbie- Postprocessor? | RP Designs | LinuxCNC (formerly EMC2) | 4 | 09-11-2009 04:00 PM |
| postprocessor | radiocbmhaaks | Post Processor Files | 0 | 11-09-2007 06:24 AM |
