Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 03-28-2011, 10:09 AM
camtd is on a distinguished road
Process Sheets
I haved used Nx7 to create tool drawings.
How are process sheets created to show a Aerospace turned part with holes in the final product?
I would like to have the process sheet show the part cut away at each sequence of the manufacturing operations.
Ex.
OP005 RELEASE MATERIAL
OP010 QUALIFY
OP020 ROUGH TURN SIDE 1
OP30 ROUGH TURN SIDE 2
OP40 HEAT TREAT
ETC.
At each operation I would like to show only what is machined. Is this done with Simplified reps or is there a better and easier way?
Thank You
Old 03-29-2011, 01:05 PM
markrief is on a distinguished road
I suggest you look in to Teamcenter Manufacturing, where there is a part planner application.
Mark Rief
Siemens PLM
Need Help!- X3 SET UP SHEETS CNC_BOB Mastercam 2 03-16-2010 09:10 PM
X4 Setup sheets 72k5 Mastercam 7 03-04-2010 12:55 PM
Build Thread- set up sheets 1234567 BobCad-Cam 4 10-27-2009 01:38 PM
Just IN- Tooling sheets Chris B Hofer Canadian Club House 2 12-22-2008 09:15 AM
Panel saw that will cut 4ft x 8ft sheets Router Lady Want To Buy...Need help! 1 09-17-2008 11:09 PM
