Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 03-14-2011, 09:09 AM
Rocketeer_88 is on a distinguished road
Question UG NX 7.5 modeling
Good day to everyone out there.
Need help on this as I'm facing challenge to construct a model.( as attached .prt file).
It calls for the wall of the port to be radiate from center while holding the port dimension on the ID. The attached sketch's port wall is straight.
Would appreciate some advice to guide me thru this as I'm still in the beginning of learning curve.
Thanks in advance.
Rocketeer_88
Old 03-14-2011, 11:35 PM
blmmdes is on a distinguished road
Hi Rocketeer_88,
Its pretty straight forward in NX and its parametric too. Please find attached the solution. Since i dont know which version of NX you are using I made it in parasolid.
The method is as follows.
1. project your sketch on the ID of the cylinder.
2. Devide the ID face with the projected curves.
3. Make a thicken sheet using the devided face (-50 and +50) and subtract.
You are done.
The trick is thicken sheet which creats a solid always perpendicular to face.
Regards,
NX 7.5.2.5
Ananth Kulkarni
THE GREATEST OAK WAS ONCE A NUT WHO HELD ITS GROUND
Old 03-15-2011, 02:13 AM
Dear blmmdes,
Really appreciate for your kind support.
Would need your help to share the .prt in order to synchronize my understanding with your explanation.
Thanks for your previous enlightening guidelines.
Best regards.
Old 03-20-2011, 10:37 PM
Sorry for the delay. Here is the part file.
Ananth Kulkarni
3d Solid modeling mapinto General CAD Discussion 8 10-22-2010 02:48 PM
FEM modeling and calculations timoty Mechanical Calculations/Engineering Design 0 05-28-2009 06:06 AM
RFQ for Guitar modeling osoloco69 Employment Opportunity 5 05-29-2008 10:45 AM
Modeling Files larry53 Computers and Networking 2 12-19-2007 11:37 AM
3D Modeling help lilricky2 BobCad-Cam 5 11-04-2005 09:13 AM
