Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 01-25-2011, 02:25 PM
seven3 is on a distinguished road
cutter compensation
Hi please can anyone help? I have some training coming but cant wait and want to play. all the tool paths that I post are missing cutter comp.(g41/g42) what am I doing wrong?
do I need to use tracking points in tool setup?
How?
Old 01-26-2011, 11:07 AM
camster is on a distinguished road
On the Non-Cutting moves dialog click the More tab and activate the Cutter Comp.
It depends on how you intend to use cutter comp if you need to use the tracking point.
When you are using the system as designed, meaning you specify the tool size in NX and at the machine the value in the cutter comp is the diference between the programmed size and the actual measured size of the tool, usually a small value then you don't need thetracking point. It is at the tip and center of the tool.
If you intend on entering the size of the tool at the machine in the comp table then you will need to use the tracking point at the tool diameter. Not my personal choice.
John Joyce -NC Programming Supervisor
Barnes Aerospace, Windsor CT
Old 01-27-2011, 01:55 PM
Thanks so much. it's so much easier when you know what you are doing, I have looked nearly everywhere for that button and never would have thought to look there.
Cutter Compensation Southbend Sam Dynapath 3 11-30-2010 03:07 PM
Cutter Compensation TravisR100 NCPlot G-Code editor / backplotter 2 10-31-2010 02:09 PM
Cutter compensation.. driftmaster Mastercam 18 04-03-2010 02:14 PM
Cutter compensation???? Clawsie Machine Cincinnati CNC 6 11-13-2008 01:19 PM
Cutter compensation? Tonenc G-Code Programing 4 11-02-2005 11:53 PM
