Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 01-05-2011, 05:21 AM
seven3 is on a distinguished road
missing circle centres
Please can anyone help, I am using nx7.5 and when posting fanuc files everthing is fine but when posting Heidenhain files the circle centres are not all in place it appears that the post is treating the circle centre as modal but the machine will not run like this.
Old 01-10-2011, 08:26 AM
Brewmeister's Avatar
Brewmeister is on a distinguished road
In Post-Builder, On the "Program & Tool Path" tab, select the "Word Summary" sub-tab.
Scroll down to I,J & K. Find the "Modal?" column, and set I, J & K to "No"
"Of course, that's just my opinion. I could be wrong!"
T Briggs (CAM dude) - Siemens PLM Software
write gcode for circle with 4 small circle inside it Farzaneh_2010 G-Code Programing 3 12-13-2010 10:24 AM
Need Help!- Motors missing steps on circle RockBoy DIY-CNC Router Table Machines 3 01-08-2010 11:37 PM
CNCOffsetCalc - automate offset setup on machining centres ZedB General CAM Discussion 0 07-28-2008 06:20 PM
Problem- circle AngelT Mach Mill 1 06-30-2008 08:59 AM
grob cnc machining centres scappini CNCzone Club House 0 07-31-2006 03:40 PM
