Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 12-14-2010, 08:50 PM
seijack is on a distinguished road
Handed Parts Left/Right
Hello All,
I have changed jobs and now I am working with UG NX 7.5 from Mastercam
X4...I have not had too many problems..but there is a learning curve..
My question is I machine many handed parts is there an easy way to program the opposite hand once you have one done..
in a nutshell I have been saving my file as the opposite part# mirroring the part. Hiding the original then referencing the original paths to the new part....still having to pick geometry for the new part...there has to be an easier way....
With Mastercam I was able to mirror the toolpaths and run them the opposite direction....
Thanks In Advance
Old 12-16-2010, 03:53 PM
markrief is on a distinguished road
You can mirror and reverse tool paths in NX also. Select the operation, object, transform to get to the mirror options. Use tool path, Edit to reverse the path.
If you are using master model, you might look at mirrored components. There may be ways to avoid reselecting the geometry.
There are many ways to do this :*)
Mark Rief
Siemens PLM
Old 12-18-2010, 05:38 AM
Thanks I will look in to doing this. I was begining to wonder if it was possible..all lookers and no replies...It may take me a bit to get to it. Thanks a bunch!!!!
Old 12-20-2010, 03:52 PM
If you want to learn NX CAM, there are many many sources of information already available to you - the CAM Express tutorials, the extensive help documentation, and the customer forums hosted by Siemens PLM. There is also training available from SPLM and third parties.
Mark Rief
Siemens PLM
How To Make A Left Handed Part From A Right Handed Model??? 61SedanMan Haas Mills 19 04-08-2010 12:06 AM
left handed rope thread GeorgN General Metalwork Discussion 5 04-07-2010 11:29 PM
Left over Allen Bradley parts RICHARD ZASTROW General Electronics Discussion 4 01-14-2010 08:50 PM
RFQ-5 left and 5 right rbest27 Employment Opportunity 3 02-27-2009 07:49 PM
Right or Left Handed? Asinity General Metal Working Machines 6 09-08-2008 02:04 PM
