Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 10-19-2010, 09:15 AM
weirdharold's Avatar
weirdharold is on a distinguished road
Wire EDM Help
I have a 4 axis wire edm post that I made with PostBuilder and have been using it for over a year now. It has one problem. No matter what the MCS is set to, the program is always generated based on the position of the WCS. To work around this, I have simply been using Instance Geometry to move a copy of the part to the position I need and then create my program.
My question is this: Is there a command or something that I can add to my post so it recognizes the MCS as the program zero? I don't know if I'm just missing something, doing something wrong, or is this just how the wire posts created in PostBuilder work.
Any help will be appreciated!
Regards,
Harold Cobb
Old 10-26-2010, 09:02 AM
andrenxcam is on a distinguished road
Hello friend your post is wrong attachment follows the example
my post generated from the MCS if you want to test my post send me an email to andrenxcam@yahoo.com.br
example: executed in the diameter of the 20mm mcs in center.
% (Tue Oct 26 11:52:17 2010)
N10 (C:\Program Files\UGS\NX 6.0\UGII\model1.prt)
N20 (sdsdd)
N30 (EXTERNAL_TRIM)
N40 G92 G00 X0 Y0
N50 G60
N60 M20
N70 G38
N80 G29
N90 EXTE
N100 G01 X12500 Y0
N110 G01 X10000 Y0
N120 G02 X0 Y-10000 I0 J0
N130 G02 X-10000 Y0 I0 J0
N140 G02 X0 Y10000 I0 J0
N150 G02 X10000 Y0 I0 J0
N160 G01 X12500 Y0
N170 G01 X10000 Y0
N180 G02 X0 Y-10000 I0 J0
N190 G02 X-10000 Y0 I0 J0
N200 G02 X0 Y10000 I0 J0
N210 G02 X10000 Y0 I0 J0
N220 G01 X12500 Y0
N230 M02
ANDRÉ LUIS DO NASCIMENTO
SPECIALIST CAM APPLICATIONS MULTI AXIS / IS&V (NX)
Old 10-27-2010, 08:30 AM
markrief is on a distinguished road
The postprocessor should only see MCS coordinates, so something is wrong here. The WCS is never used.
In the geometry view ofthe operation navigator, are all the groups and operations under the MCS?
If you move the WCS and post again, do the coordinates change?
Mark Rief
Siemens PLM
Old 10-27-2010, 11:59 AM
Smile This is what I have.
I"m not sure this structure is correct. Never have fully understood the correct way to do this. I have noticed, that when I change my MCS, to the correct axis I need for our Robocut wire, it revert's back , 90 deg off , like it does not want to stay, if that make's any sense. I'm including the correct program to cut this part. If I post the code out with the part placed like it is in the picture , I'm 90 Deg. off. Regards,
Harold Cobb
Name:	7 degree recutter_Wire2.jpg‎
File Type: txt 7 degree recutter_Wire.txt‎ (469 Bytes, 15 views)
Old 10-27-2010, 06:29 PM
There should be a MCS_WEDM at the top of the tree, with a workpiece, optionally WEDM geometry groups, and then the operations.
Start by creating a WEDM setup, not a milling setup.
Mark Rief
Siemens PLM
Old 10-27-2010, 06:46 PM
Smile Thank's !!
That's the trick !! You got me thinking when I was at home this morning about what you posted earlier, & now that I'm at work & opened it up & did what you just posted, code is correct. Many thank's for helping resolve this.
Regard's,
Harold Cobb
Running stepper motor wire with router wire? basskitcase DIY-CNC Router Table Machines 2 02-19-2010 10:18 AM
Wire EDM - Wire Type and Size greenchair General Metal Working Machines 0 06-17-2009 01:44 PM
I have 6 wire motors can I use a 4 wire driver Musick7 Stepper Motors and Drives 10 05-05-2009 10:39 PM
power supply size? for multi wire (total 250 inches of wire) DanOSB CNC Wire Foam Cutter Machines 5 03-02-2009 04:34 PM
How to wire an 8 wire stepper motor technosteve DIY-CNC Router Table Machines 1 01-16-2009 05:01 PM
