| UG NX UG CAD/CAM Discussion |
Please can anyone advise, I am trying to produce a rotary axis milled part by rotating the b axis and spiraling along the part in x. When I verify the path it looks great but when I post it I have x,y,z,b axis moves how can I stop the y axis moving so that the mc only moves in x,z,b axis? Thanks |
| Make sure the Tool axis is pointed away from the center of rotation and the Projection Vector is Toward the center of rotation. I will often use away from line for the tool axis and define a line thru the center of rotation. What are you using as the Drive geometry? You may need to create a cylinder and use that as the drive geometry.
__________________ John Joyce -NC Programming Supervisor Barnes Aerospace, Windsor CT |
From the List of User Defiend events select Lock Axis Enter the Axis you want to LOCK and the Plane of rotation From your description you want to lock the Y axis and the rotation plane sounds like the ZY - this you may need to test Post your program and see if this forces rotary motion.
| A 5-axis CNC machine including a rotary axis | synthetiklone | CNC Wood Router Project Log | 11 | 05-23-2012 09:31 PM |
| Rotary head development 3 axis -> 5 axis | Mr Helmut | Mechanical Calculations/Engineering Design | 1 | 08-03-2010 05:26 PM |
| Rotary axis | WinD84 | LinuxCNC (formerly EMC2) | 2 | 02-23-2010 12:54 AM |
| Dro on a rotary axis. | Smackre | DIY-CNC Router Table Machines | 7 | 01-16-2007 07:45 AM |
| 4 Axis Rotary | Smackre | Mastercam | 3 | 08-09-2006 11:28 AM |
