Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 05-09-2010, 09:55 AM
gaoxingdcf is on a distinguished road
Converting a pdf file to UG part file
Hi all, i need help in converting a pdf file to a UG part file
I'm using NX5 for drawing.
Is there any software that i can convert it ??
Thanks for viewing.
Mods,if it is in the wrong section, please kindly move it to the correct section
TIA !!
Old 05-19-2010, 07:47 PM
andrenxcam is on a distinguished road
YES you can have software PDF to DXF
WHERE YOU MATTER TO GENERATE AND DXF NX and converts it into 3D
HUG
ANDRÉ LUIS DO NASCIMENTO
SPECIALIST CAM APPLICATIONS MULTI AXIS / IS&V (NX)
converting a .sldprt solidworks file into a .stp or parasolid file avogtster Solidworks 3 02-26-2010 01:40 AM
converting a mastercam 9 file into a Solidworks file Michael82 Solidworks 5 04-17-2009 01:14 PM
Help converting .fgc file slammedxonair DynaTorch 1 02-12-2009 03:19 PM
Need Help!- Need a favor. STL converted to part file or solidworks part file. Cmzwirner Solidworks 3 12-11-2008 07:45 AM
Converting ACAD DWG into Inventor Part file phil m Autodesk Software (Autocad, Inventor etc) 2 11-21-2007 12:03 PM
