Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > UG NX
UG NX UG CAD/CAM Discussion
Old 03-01-2010, 12:46 PM
Rumm64's Avatar
Rumm64 is on a distinguished road
NX7
Well, we're jumping from NX4 to NX7.
On the manufacturing side, I was wondering if anyone
else has ran into this problem?
Toolpath intentions: Pick out a fillet on a non-planer cavity floor,using a 1/4" ball endmill.
In Fixed Contour setting up a open boundry with mulitple stepover's
(boundry is tangent to a cavity wall). On the engage, I set OPEN AREA at
.100 plunge, and set Against Part/Check at NONE.
(part geometry is body)
But graphics are showing the engage and retract starting/ending .100 above the cavity wall.
(If the cavity wall is 3" tall the engage/retract move is 3.100"
I want the tool to engage .100 above the cavity floor.
Any thoughts??
Old 03-01-2010, 01:29 PM
Rumm64's Avatar
Heres a picture of toolpath --notice the closer it gets to the wall
the longer the engage (red) and retract (yellow) gets.
Old 03-01-2010, 04:00 PM
Rumm64's Avatar
Opps
Found the problem --
Old 04-06-2010, 09:15 AM
1 Infinite Loop's Avatar
1 Infinite Loop is on a distinguished road
Yes, this post may qualify as thread necromancy
Another setting that may affect the engages/retracts is cutting-clearances-part safe clearance.
I cannot tell from the image if the floor is flat or not. If it is flat, another operation that may work well for you is z-level profile and set the cut level to optimized. I use it a lot with great results.
Jim
CNC Programmer, NX 7.5, NX 8.0
