The Engraving operation works with a Note - like a note from drafting.
If you want to cut lines and arcs then use planer mill and make ON boundaries. Set the cut pattern to Standard drive. Define the floor. You can use a negative floor stock or offset the floor into the part the depth of the "Engraving"
