- contour Area milling posted 3D points are too coarse.
Hi all members.
I am facing a problem in NX 8 CAM. I make a operation using Contour Area milling,3D points are not close this is because machine is not running in uniform motion i.e vibration in slides can be feel. Moreover How the tool path can be post in the format using G18 and G19?
Regards,
Rehanali
Re: contour Area milling posted 3D points are too coarse.
There could be many factors influencing this. For example, we have made several enhancements to the point distribution and arc output on analytic geometry since NX8 was release 4 years ago.
Please contact GTAC or your reseller for support on this.
- You may not post replies
- You may not edit your posts
Forum Rules
