Question change CNC G-Codes, From "I J K" to "R"
Results 1 to 1 of 1
Thread: Question change CNC G-Codes, From "I J K" to "R"
    Question Question change CNC G-Codes, From "I J K" to "R"
    • Hi
      I'm working to build a new post using HEIDENHAIN controller with NX Post Builder.
      5-AXIS head\head CNC Machine with NUM Controller.
      I need to change my CNC Output G-Codes, From "I J K" to "R".
      I'm beginner to post builder.
      I need for some help.
      Tanks a lot.
    Oct 2016
    Iran, Islamic Republic Of
    Default Re: Question change CNC G-Codes, From "I J K" to "R"
    hey
    i had this problem once and with people's help it got fixed
    you have to go this way to fix your problem
    first of all open the post builder application if it doesn't have any problem
    then open your post processor and follow this path :
    Go into "Program and toolpath" -> Motion -> select "circular move"
    delete the I, J and K words
    in the "drop" list to the right of "Add word" - select "R" -> "R - Arc Radius" (might be named slightly differently depending on "controller" template used to create the post, and if you have a lot of words, you might have to click on "more" to see it).
