- Need Help!- Problem with NX7.5 Lathe cam post
Friends , I got a problem with my UG NX 7.5 Lathe CAM. the posted programs had the x values in radial method. but my CNC lathe with sinumeric 802 controller is with Diametrical type of programing. ie if we need a 10 mm dia to be turned, by using NX 7.5 Lathe cam the output program have the value of x as 5 mm. please get me a way out.
Varun
Re: Problem with NX7.5 Lathe cam post
If you can edit the post in Post Builder,set this in Machine Tool, General Parameters, Axis Multiplier, Diameter Programming .
- You may not post replies
- You may not edit your posts
Forum Rules
