- create blank geometry of woprkpiece-op2 from ipw of workpiece-op1
Re: create blank geometry of woprkpiece-op2 from ipw of workpiece-op1
WORKPIECE-OP1 and WORKPIECE-OP2 should reference part geometry in instances of the same component.
For example, the same part in multiple vises; or positioned face face side up and upside down.
GTAC should be able to help you with IPW flow if the help documentation is nto clear.
In NX9, you can also use copy/paste for many of these situations. Take a look at
Faster CNC programming for setups with multiple pa... - Siemens PLM Community
- You may not post replies
- You may not edit your posts
Forum Rules
