- Need Help!- Uccnc hdbb2 wiring help needed
I am in the process of putting together a cnc controller box using 3 leadshine em705 stepper drivers 48 v 600 watt power supply + 12volt power supply for uccnc hdbb2 E-stop 3 homing switches basically a normal X Y Z system for routing wood. Can someone please point me to a wiring diagram for the hdbb2 or a wiring diagram that would be similar. The instruction pdf from uccnc for the hdbb2 Is very technical but not very visual for a newcomer like me. I wait with bated breath. Thanks in advance. Ps Iam am using a uc100 usb thingy.
Andrew
Re: Uccnc hdbb2 wiring help needed
Did you ever get a reply?
- You may not post replies
- You may not edit your posts
Forum Rules
