Arc + Ramp = Helix issues - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
Thread: Arc + Ramp = Helix issues
  1. #21
    Mar 2010
    America
    Default Re: Arc + Ramp = Helix issues
    Thinking about it I fell in the same hole as msimpson, you think when using the mach3 XML import your settings are good to go and this is not the case.
    Dan
  2. #22
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    UCCNC has settings that Mach3 does not, and Mach3 has settings that UCCNC does not, so you're never going to get a 100% ready to run profile by importing your Mach3 profile.
    I've always thought it's a bad idea to use an .xml from someone else with Mach3. If you setup the machine yourself, you'll know a lot more about your machine, and how to fix problems that come up. If you just want to import a profile and hit run, you're at someone else's mercy when it doesn't work.
    Teach a man to fish......
    UCCNC 2017 Screenset
  3. #23
    Its nothing about the settings that one has over the other. If you are setting up manually or importing, there should be a popup or a setting that changes the settings to values that work with inches. When importing an XML file it should read the unit type and change or at the very least warn you. These kinds of oversites just make the software a little less inch friendly.
    Also the rabbit hole that I fell down was deeper as it was compounded by the display bug. All is good now. I just cut my first complex part and it came out perfect. absolutely no cut lines which is saying alot when machining soft plastic. I will be posting a video if this soon.
    I'm really liking the UCNCN software. It is now a just getting a handle on its little quirks. For instance when I tried running a job it kept giving me a softlimits error. It did not like the idea of me going to X0 and Y0 at the end of the job. On UCCNC you have to be > than the softlimit so a Job setting of zero or less will trip the job softlimit. Kind of kooky as it lets you jog to X0 and Y0.
    I didn't want to regen a lot of Gcode so I just set my X and Y soft limits to X -.0001 and Y - .0001. Problem solved.
    Author of: The CNC Construction Set Books, the KRMx01, KRMx02, KRmc01, and KRmf70 CNC Books, the HANS Electric gear clock book. All available at www.kronosrobotics.com.
  4. #24
    I'm also sorry about the title I gave this post as the issues had nothing to do with doing a G3 Helix cut. If I had looked carefully at the code I would have seen that there were actually not helix cuts being generated.
  5. #25
    Apr 2013
    Sweden
    Quote Originally Posted by msimpson99 View Post
    I think UCCNC is just as inch friendly as millimetre friendly since it is totally unit-less, but you must read the manual. While it could be improved, it is pretty clear. The import function is good, it gets you started, but after that you must start thinking on your own because no import function can be relied on to 100%. Importing is a compromise.
    https://www.youtube.com/c/AdaptingCamera/videos
    https://adapting-camera.blogspot.com
  6. #26
    Mar 2010
    America
    I agree, on the first or second line of a Mach3 XML gives the units used. I don't think it would take much to replace the mm UCCNC default settings with imperial when using the Mach3 XML import feature.
    Dan
  7. #27
    After making the above changes I made my first part using UCCNC.
  8. #28
    Jul 2013
    good thread, need to be a sticky. I am too running into issues with UCCNC.
    Question, are the motor settings also unit-less?
  9. #29
    Jun 2015
    Sweden
    Read my reply in the other topic you posted: https://www.cnczone.com/forums/uccnc...98410-cam.html
  10. #30
    Jul 2013
    Thank you !
