open and close suction vents
Results 1 to 14 of 14
Thread: open and close suction vents
    Aug 2007
    New Zealand
    Default open and close suction vents
    I have built my down draft table on my plasma with air rams to open and close each section of the table so i can direct the suction to the area the torch is working in, i would like to automate this process.
    I originally was going to build some switches into the zones on the y travel path and arduino it up to open and close but I think it would be more elegant if its handled within the uccnc software.
    Once the machine is homed then the vents become available, this way i don't have vents opening and closing randomly because that origin is off.
    Once available, Y position (machine coordinates) would
    Y0 - 999mm output 1
    Y1000 - 1999mm output 2
    Y2000 - 2999mm output 3
    y3000 - 3999mm output 4
    I suppose you could even go Y 500 - 1500 output 1&2, i think you get the idea.
    I would prefer not to have this solved by embedded outputs in the gcode (from the post processor).
    Can someone smarter than me suggest how I would go about making this work?
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: open and close suction vents
    macroloop?
    If you ask on the UCCNC forum, someone may even write one for you.
    UCCNC 2017 Screenset
    Apr 2014
    Do you want to enable the outputs only while g-code is running?
    Apr 2014
    I didn't wait for you answer. Set the limits and the output pins as your needs. If the outputs are active low, change ventxNeg to "true". Save code to Mxxxxx.txt where xxxxx is a number (e.g. M10000.txt) and go to General settings / Config macroloops, add 10000 (or the number you selected) to an empty row, set Auto run, click Run, click Save settings. Ready.
    Code:
    // Auto open vents
    int newState = 0;
    double yPos = 0.0;
    if (exec.GetLED(RunLED))
      yPos = exec.GetYmachpos();
      if ((yPos >= lim0) && (yPos < lim1))
        newState = 1;
      else if ((yPos >= lim1) && (yPos < lim2))
        newState = 2;
      else if ((yPos >= lim2) && (yPos < lim3))
        newState = 3;
      else if ((yPos >= lim3) && (yPos < lim4))
        newState = 4;
    if (newState != lastState)
      Clroutpin(vent1Port, vent1Pin, vent1Neg);
      Clroutpin(vent2Port, vent2Pin, vent2Neg);
      Clroutpin(vent3Port, vent3Pin, vent3Neg);
      Clroutpin(vent4Port, vent4Pin, vent4Neg);
      switch (newState)
        case 1:
          Setoutpin(vent1Port, vent1Pin, vent1Neg);
          break;
        case 2:
          Setoutpin(vent2Port, vent2Pin, vent2Neg);
          break;
        case 3:
          Setoutpin(vent3Port, vent3Pin, vent3Neg);
          break;
        case 4:
          Setoutpin(vent4Port, vent4Pin, vent4Neg);
          break;
      lastState = newState;
    #Events
    // =============== Constants
    const int vent1Port = 2;                                                        // Port number of vent 1
    const int vent1Pin = 2;                                                         // Pin number of vent 1
    const bool vent1Neg = false;                                                    // Invert pin of vent 1
    const int vent2Port = 2;                                                        // Port number of vent 2
    const int vent2Pin = 3;                                                         // Pin number of vent 2
    const bool vent2Neg = false;                                                    // Invert pin of vent 2
    const int vent3Port = 2;                                                        // Port number of vent 3
    const int vent3Pin = 4;                                                         // Pin number of vent 3
    const bool vent3Neg = false;                                                    // Invert pin of vent 3
    const int vent4Port = 2;                                                        // Port number of vent 4
    const int vent4Pin = 5;                                                         // Pin number of vent 4
    const bool vent4Neg = false;                                                    // Invert pin of vent 4
    const double lim0 = 0.0;                                                        // Zone limits
    const double lim1 = 1000.0;
    const double lim2 = 2000.0;
    const double lim3 = 3000.0;
    const double lim4 = 4000.0;
    const int RunLED = 19;                                                          // On when code is running
    // =============== Static variables
    static int lastState = 0;
    // =============== Set/Clr output
    void Setoutpin(int port, int pin, bool neg)
      if (neg)
        exec.Clroutpin(port, pin);
      else
        exec.Setoutpin(port, pin);
    void Clroutpin(int port, int pin, bool neg)
      if (neg)
      else
    Aug 2007
    New Zealand
    Quote Originally Posted by dezsoe View Post
    Code:
    // Auto open vents
    int newState = 0;
    double yPos = 0.0;
        newState = 1;
        newState = 2;
        newState = 3;
        newState = 4;
      switch (newState)
        case 1:
          break;
        case 2:
          break;
        case 3:
          break;
        case 4:
          break;
    #Events
      if (neg)
      else
      if (neg)
      else
    Im not sure this will solve the problem, when i do things like rip cut the vents wont open? If i understand correctly
    Sent from my SM-G920I using Tapatalk
    Apr 2014
    Sorry, I don't know what is "rip cut". I thought you only need the vents while running. If you write some more details of what you need, then I can modify this macro.
  7. #7
    Mar 2010
    America
    Guessing what he means is cutting along the X axis. Obviously the macro you provided is easily editable and you can only guess how his table/vent ports are setup.
    "Thank you Dezsoe" I copied and saved for future reference.
    Dan
  8. #8
    Apr 2014
    He can cut along the X axis. If the Y is in the given ranges the vent will be on. Maybe, he wants to cut with MDI commands or manual jog. It can be enabled, of course, but I thought, it's not important to run the vent while no code is running.
  9. #9
    Mar 2010
    America
    Yes I see that, what vent is open is dependent on Y position, I was just pointing out that its easily editable to adjust.
    Makes perfect sense to me only activate when Gcode is running.
    I was also trying to subtly point out he could of been more appreciative you taking your time to write it..
  10. #10
    Aug 2007
    New Zealand
    Ive pretty much solved this by having a homing routine then having a macro running to enable disable the output given on the x and y position.
  11. #11
    Mar 2010
    America
    Quote Originally Posted by jrslick22 View Post
    Not going to post your macro solution that could help others??
  12. #12
    Apr 2014
    Nice! That is what my macro does. The only difference is that the request was to check only the Y axis.
  13. #13
    Aug 2007
    New Zealand
    the dude who did the work for me did it on the condition that I protected his I.P. happy to point people in the right direction tho
  14. #14
    Mar 2010
    America
    OK Np, If anyone similar to your needs can just use the macro Dezsoe posted... it works well.
    Dan
