Your axis velocity setting is 2000 is why it does not go above 2000. The velocity parameter is the speed constraint for the axis.
You should change that higher only if your axis can handle the higher speed, you should verify that.
If your other axis is also set to 2000 velocity just for an example then the fastest feedrate you can get on the path is when the 2 axis move in 45°, then you will get sqrt(2000^2 * 2000^2) speed which is 2828 feedrate on the path and this is when both axis move with 2000 velocity creating the mentioned path feedrate.
