New UC300ETH breakout board. - Page 5
Page 5 of 10 FirstFirst ... 2345678 ... LastLast
Results 81 to 100 of 184
Thread: New UC300ETH breakout board.
  1. #81
    Oct 2015
    Default Re: New UC300ETH breakout board.
    Quote Originally Posted by xillianto View Post
    I would have gone with uc300 and uccnc aswell if i didnt have my pokeys57cnc board and mach4 lisence
    Sent fra min SM-G930F via Tapatalk
    I have Mach3 and Mach4 along with the eth-SS but after reading so much about uccnc and Ger21's post on various forums I took the plunge for Uccnc and the UB1-300eth, should be here tomorrow I can't wait.
  2. #82
    Nov 2006
    Thailand
    Quote Originally Posted by Regulator View Post
    Hi Guys,
    I think you guys get it in the same day but different geographic time zone.
    New Zealand come first in the list. About 8 people have to wait about 2 weeks time with snail mail delivery.
    I'd like to see them installed and run on the real machine, really want know how it performs and the feed back from you guys.
    Thank you for all your supports.
    Weerasak.
    Attached Thumbnails Attached Thumbnails New UC300ETH breakout board.-trackingtable-jpg
  3. #83
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Looks like Fedex may have dropped the ball on mine, unless it shows up in the next 30 minutes (7:00 PM)
    This morning, it still said delivered by 10:30, then changed to today, which it still says.
    But the tracking history says it went from Thailand, to Alaska, then Taiwan. And it still says Alaska.....
    UCCNC 2017 Screenset
  4. #84
    Mar 2003
    Shelby Township
    Well, that sucks.
    My UB1 went from Thailand, to Alaska.
    Then, from Alaska, to Taiwan.
    Then from Taiwan, back to Alaska, where it apparently just left, when it was supposed to be here this morning.
    So maybe I'll get it sometime tomorrow, as it's probably a 6+ hour flight from Alaska?
  5. #85
    Oct 2015
    Hi Ger21 you're not alone! I called them because mine said the same thing, its still in Alaska, it shows up odd because of the time diff, any way when I called they said they would have one of their tracking people get on it, they called me back and the investigator explained about the time difference and said, so its some type of circuit board? and I explained what it was and they said that I should have it tomorrow. So I'm sure that's what happened to you as well.
  6. #86
    Apr 2014
    Well, mine was delivered safe and on time
    I posted the following on the cncdrive forum
    first impressions are a very neat and well made board.
    I am not posting any specific parameters as the manual will no doubt provide switching current limitations etc.
    the 3 onboard relays seem quite fast switching time (sub 1msec operate & release)
    https://www.fujitsu.com/downloads/MI.../relays/sy.pdf
    And the (standard inputs / outputs [i.e. non motion control!! / step + direct]) optoisolators appear to be TLP185, which are fast, have good voltage rating (24V well in their parameters) and good package power dissipation relative to others on the market.
    http://www.farnell.com/datasheets/1646144.pdf
    I await a suiable daughterboard (neatest option seems to be the CNC4PC C10S which is 26PIN IDE <> IDE plugin compatable..... unfortunatly only 5V rated from what I can see.
    Note: they do an non "S" variant although this will require a LPT connector, IE not as compact and has screw terminals where as the "S" has the IDE connector or LPT and push in terminals (same as the UB1)
    https://cnc4pc.com/c10s-bi-direction...face-card.html
    I will have mine installed in the next week.
    I'll do a grabcad model of it first for the mounting holes etc
    Similar to this
    https://grabcad.com/library/neuron-p...l-controller-1
    Attached Thumbnails Attached Thumbnails New UC300ETH breakout board.-c10s-jpg
  7. #87
    Oct 2015
    Congrats Robert on getting yours, mine is slated for 1030am today but I'll be at work, it makes you feel like a kid waiting for a new toy...lol. In reality I still have a few days left on my machine build so it doesn't really matter. Thanks and look forward to your feedback.
  8. #88
    Mar 2004
    UK
    Mine's in snail mail
  9. #89
    Oct 2015
    Mine came this morn but unfortunately I'm at work till 8 pm
  10. #90
    Mar 2003
    Shelby Township
    Yeah, nobody home at my house either, and they didn't leave it. I called Fedex and had them hold it for pickup, but I won't be able to get it until after work tomorrow.
  11. #91
    Mar 2003
    Shelby Township
    I wired it up today and did some quick testing. Everything works great.
    I also updated my 2017 screen to support the UB1, but it requires a yet to be released version of UCCNC.
    I'm hoping to get a DMM servo running this week. Spent an hour tonight soldering up a DB25 cable. I'll be getting a new soldering iron soon, after that.....
    Attached Thumbnails Attached Thumbnails New UC300ETH breakout board.-ub1_2-jpg
  12. #92
    Mar 2014
    Looks nice. I want one but I'm too far along with the MB2 to change hings up. I might upgrade my friend's router though...
  13. #93
    Jan 2014
    Hi Gerry,
    How does one get updates for the Screenset?
    Cheers!
    Dale
    "I also updated my 2017 screen to support the UB1, but it requires a yet to be released version of UCCNC."
  14. #94
    Mar 2003
    Shelby Township
    I send out emails whenever I release an update. I haven't sent an email about this version yet, because the version of UCCNC that it requires has not been released.
    If you haven't received any email updates from me, send me an email and I'll check my address book.
  15. #95
    Jan 2014
    Thanks Gerry,
    I figured it would be something simple as that.
    Cheers!
  16. #96
    Mar 2004
    UK
    Received my UB1 today. Hooked it up and had a quick play around.
    Very nice quality. Happy customer.
  17. #97
    Jan 2017
    This is awesome. Just ordered one.
  18. #98
    Mar 2003
    Shelby Township
    I wired mine up to my test board and tested most of the functions, and everything works as advertised.
    Analog inputs with pots for FRO and SO.
    Charge pump. I have the charge pump output activating a relay, which controls power to a PILZ safety relay. The safety relay controls a contactor to enable the servo drive power, so the servos can't be powered up until the charge pump comes on. Estop kills power to the safety relay, and power to the servo drives.
    I'll probably use the UB1 safety circuit for the fault signals from the servo drives.
    Inputs and outputs work as advertised.
    On board relays work fine.
    I basically just swapped the wires from the MB2 to the UB1. Quick and easy..
    Much cleaner installation than the MB2.
    The UB1 is definitely the way to go if you're buying a UC300ETH.
  19. #99
    Sep 2005
    Indonesia
    Hello Gerry,
    Is it good to use with Gecko G 320 X with UB1 and UC300ETH?
  20. #100
    Mar 2003
    Shelby Township
    Any step/direction drives should work fine with the UB1.
