New UC300ETH breakout board. - Page 4
Page 4 of 10 FirstFirst 1234567 ... LastLast
Results 61 to 80 of 184
Thread: New UC300ETH breakout board.
  1. #61
    Mar 2004
    UK
    Default Re: New UC300ETH breakout board.
    Order placed
  2. #62
    Apr 2014
    order placed, apparently they ship out next wednesday (ish).
    Looked at an MB2 for the use of ports 4&5..... problem is, this is a no go if you read the manual as only one of the three ports on the MB2 is an EPP/ECP (pins 2-9 as inputs configuration)..... both port 4 & 5 of the UC300 are pins 2-9 as input.
    C10 [or cutom bob...]
    Attached Thumbnails Attached Thumbnails New UC300ETH breakout board.-mb2-inputs-ess-png
  3. #63
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    I sold my MB2 yesterday, and ordered the first UB1 this morning.
    I had some questions for Weerasak, so I also asked about the possibility of a daughterboard down the road.
    UCCNC 2017 Screenset
  4. #64
    Mar 2004
    UK
    My build using the Ub1 will be 3 axis with a slave. I presume there is nothing to stop me using the B and C step and direction outputs in single ended setup for standard outputs (only 5v capable obviously)?
    Robertspark, how many inputs do you need? Usually if you have a lot of inputs from a machine (say a converted mill with an ATC) you would be handling them with a PLC.
    For instance, on my next build I will have a small PLC monitoring all the spindle and air sensors and running all the solenoids with just 1 output from the controller to request a tool change and one input to acknowledge the change.
    - - - Updated - - -
    Quote Originally Posted by ger21 View Post
    Lol, I now have a brand new MB2 with an ESS installed ready to be sold.
  5. #65
    Apr 2014
    Quote Originally Posted by matth View Post
    Robertspark, how many inputs do you need?.
    You can use the io's for whatever you want, but yes they are 5v high impedance outputs but you can still drive a MOSFET.... Or my personal favourite.... Bts621...
    I don't need that many inputs really, but outputs are always handy for other items... My plan has always been to have one all in drive box, hence flexibility
  6. #66
    Mar 2004
    UK
    Quote Originally Posted by robertspark View Post
    Don't get me wrong, if a daughter board is produced I'll be getting one!
  7. #67
    Mar 2003
    Shelby Township
    According to Fedex, the UB1 will be here on Wednesday.
  8. #68
    Mar 2004
    UK
    Lucky duck.
    I'm having to play around with the standard 5LPT.
    I'm running UCCNC and your screenset today trying to get acquainted with it after years of Mach3. The UB1 would be helpful even just bench testing the software as it has indicators for all the IO's.
    UCCNC looks and feels fairly straight forward so far compared to Mach3.
    Ger, any ideas on the release date for the UCCNC version that will have the UB1 profile supported? I've looked on the UC forum but couldn't spot any info.
  9. #69
    Mar 2003
    Shelby Township
    No, but it won't really matter if you're using my screenset, as I need to update the screen to support the UB1. until then, I'd just set the jumper on the UB1 to 5LPT mode. THe only difference between them should be the diagnostic page, I think.
    Yes, I think it was a good idea on their part to make it feel a lot like Mach3, which makes it a very easy transition.
  10. #70
    Apr 2014
    Me too... Ship Monday, arrive UK Wednesday, better get into gear and get it installed asap
  11. #71
    Mar 2003
    Shelby Township
    I've been told that Monday is Mother's day (observed) in Thailand, and he's not sure if that will delay the shipment or not.
  12. #72
    Mar 2012
    Norway
    Ger, abit wrong place.. but will there be auto probe for mach4 or perhaps a screenset if possible ?
    Sent fra min SM-G930F via Tapatalk
  13. #73
    Mar 2003
    Shelby Township
    Not likely.
  14. #74
    Mar 2012
    Norway
    Not likely.
    Too bad i wanted auto z tool measurement
  15. #75
    Mar 2003
    Shelby Township
    Use UCCNC
  16. #76
    Mar 2012
    Norway
    Use UCCNC
    I wish i could, but i have pokeys57cnc controller with mach4
  17. #77
    Mar 2003
    Shelby Township
    I have a Mach4 Hobby and a Mach4 Industrial license. I'm not using either one.
    You could sell the Pokeys, and buy a UC300 ETH. UCCNC is only $60
    I thought that Mach4 had auto tool zero built in?
  18. #78
    Mar 2012
    Norway
    Not the like the one from 2010 /2017 screenset to have a fixed plate between tools
  19. #79
    Apr 2014
    Wow, that's an investment... Thought I was bad with a usb-ss + eth SS + mach4 hobby licence never to be ever used again the way uccnc is progressively developed with new development versions every few weeks to month or so. But an m4 industrial licence I would have said trump's the lot
    Just need g41/g42 and turn and would have said they were very close software wise
  20. #80
    Mar 2012
    Norway
    I would have gone with uc300 and uccnc aswell if i didnt have my pokeys57cnc board and mach4 lisence
