Need Help! Ballscrew mapping
Results 1 to 10 of 10
Thread: Ballscrew mapping
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Ballscrew mapping
    Not that I'm aware of.
    UCCNC 2017 Screenset
    Apr 2013
    Sweden
    Quote Originally Posted by cnc_rosh View Post
    Can we map ball-screw in UCCNC?
    What do you mean by "map ball screws"? You can calibrate each axis automatically or set the steps per values manually. Ball screw data is not important for the motion, what matters is the number of step pulses the software must send to get a certain motion length.
    https://www.youtube.com/c/AdaptingCamera/videos
    https://adapting-camera.blogspot.com
    Aug 2006
    Ball screw mapping is where you calibrate the screw in sections and then the motion controller applies correction depending on what part of the screw you are at. That way it can take into account any inconsistencies in the lead screw.
    Apr 2013
    Sweden
    Quote Originally Posted by derek View Post
    I see. Thanks.
    Sep 2005
    My plasma table is chain drive. Mapping would be great for chain. For example when I bought 2 brand new quality drive chains of the same brand I laid them out side by side on a flat surface to check for any difference in length over about 3m.
    Indeed there was a slight difference. Bring into the equation wear (stretch as it's often called) in certain areas of the chain and mapping would be a great calibration feature. I know high end controllers may have this.
  7. #7
    Jan 2005
    LinuxCNC has screw mapping.
  8. #8
    Jul 2006
    malaysia
    Mach3 has also Screw mapping.
    I would like very much to see this option available in UCCNC , it is very important in machines of 2000 to 3000 mm screw lengths (large routers) !
    If you need precision cutting you need to have a screw mapp.
    The other interesting part would be an input for digital linear scales. (encoder feedback) like Linux-CNC has !
    Quote Originally Posted by 109jb View Post
  9. #9
    Jul 2016
    For the UCCNC developers, is this something on the "list"?
  10. #10
    Mar 2003
    Shelby Township
    You'd have to ask on their forum, but I doubt it. There are a lot of much more important things on that list.
    How would you plan on measuring the error along your screw?
Ballscrew mapping
Ballscrew mapping
