David, I have seen the video you made to demonstrate the "issue". The only issue I see in the video is the way you test the probe function. The problem is caused by your "probe" and the fact that what you are probing is moving. You MUST fix your probed piece in order to make a secure touch contact. So, the "issue" is with your test method not the macros. Can also be some sort of electrical issue with your installation. I would like to see your settings, you are flexing too much with the camera, so it is difficult to see all the settings.
I didn't want to risk the probe during testing as a probe is a bit pricy . Basically, a probe will signal by opening or closing a switch when the switch is triggered in the X, Y or Z direction. The method I used was simple, my "switch" was the router bit with the metal plate. Both are metal and conduct electricity. When they touch, the switch is closed and the BOB accepts it the same as if a probe signal. Now that it is working, it no longer pushes the plate forward
Please answer the questions above, otherwise it is not possible to help you out or solve any of your problems. All I know is that I have used these macros for over a year and they work fine on my machine with basic touch probe. I also know that several hundred other users use it and ESPECIALLY the X and Y centering macros are very much used and welcomed and work for them also. So, you need to help me and answer my questions to understand your problems better. Right now, even with the video, I am still in the dark, and the only thing your video proves is that you can't probe anything the way you are probing, unless you get an extremely sensitive probe, not just a simple spiral drill.
Edit: I have just watched your video once again and froze the screen to be able to see your settings. Your settings are totally off. For the Z probing the probe diameter does not matter, but for X and Y it is important to set ALL the parameters right, including the probe diameter. You have the probe diameter set to 1 but the drill bit you have in the spindle collet is at least 5mm. Please read the provided manual. It is important because unless you read it and set it up according to the REAL situation, i.e. not just using the default values, you may cause damage and may have problems with the measurements.
