The default CV parameters are setup for metric use. I think you need to divide them by 25.4 for inches, which should give you much better results.
Did the screenset update I sent you work OK?
I have a file I cut with the new uccnc and uc100 set up I bought. The curves are like short lines instead of nice arcs. I dropped the exact file into Mach3 and it cut the arcs the way it was supposed to. Same file, not altered. Also on a outer profile cut it would pause for a split second when it went from a straight line to an arc. Help please.
Sent from my iPhone using Tapatalk Pro
- Need Help!- tb6560 x axis is grinding y is smooth z is smooth im a newbie
- AutoCAD (.dxf) curves importing into Enroute very choppy (not smooth)
- Need Help!- Faceting on smooth curves?
- Newbie- RPM vs. HP Curves
- Need Help!- How do you get nice smooth curves (almost like bezier curves in photoshop) in Bobcad?
UCCNC 2017 Screenset
Yes the new screen worked great. I'll try changing the cv adjustments. Thank you.
