New MODBUSEZ SetUp Plugin For UCCNC - Page 4
Page 4 of 4 FirstFirst 1234
Results 37 to 42 of 42
Thread: New MODBUSEZ SetUp Plugin For UCCNC
  1. #37
    Mar 2017
    Default Re: New MODBUSEZ SetUp Plugin For UCCNC
    I am looking for what is needed for modbus over ethernet like A_Camera has done not serial port
  2. #38
    Apr 2013
    Sweden
    Quote Originally Posted by WhiteWolf View Post
    There is a short answer here:
    2nd build - For a friend
    I am though planning a complete description of how to set it up, but that must wait about a week. Never the less, I will document it in more details, here on CNC Zone (not in this thread) or on my blog.
    https://adapting-camera.blogspot.com
    https://www.youtube.com/channel/UC_vrAWOz5YGX6_e3qtXg3YA
  3. #39
    Apr 2013
    Sweden
    Dan, I know you won't believe me and also know you asked me to get lost from this thread, but I had some time over tonight and tested the last versions. Unfortunately when any of those are enabled my UCCNC 1.2032 crash. Nothing, no change is possible, and once the plugin is enabled it is not even possible to disable it, it crash immediately at startup. The only way I can start UCCNC after that is if I edit the profile and set it to False, or if I delete the plugin. The last working version is the one in the ACTEST4.rar.zip file. All the others crash my UCCNC and I have no idea why. Admittedly, I did not do any deep testing of the one in ACTEST4.rar.zip, only clicked on the button for forward and reverse spinning of the spindle at minimum speed, but I believe that it works if the spindle would be handled in a G-code.
    I thought maybe you wanted to know...
  4. #40
    Mar 2010
    America
    Default UPDATED MODBUSEZ4 Plugin
    Hello All,
    I updated the MODBUSEZ Plugin to "MODBUSEZ4" and all other versions should be deleted since this version is most stable. The setup instructions did instruct that all register fields needed to be in hexadecimal along with other conditions, but if you mistakenly put an improper character in the register fields this could cause and exemption in plugin. This was fixed along with other minor issues. I also set register fields to only except hexadecimal as another precaution.
    My main goal when I started writing this plugin was to make setup as easy as possible, I'm hoping that the settings list of the most common VFD's continue to grow and setup is nothing more than copy/paste. I added another VFD settings (KCLY) that is successively being controlled by UCCNC with the help of MODBUSEZ4 plugin.
    Download Here>>>>>>>>>>>>>>>>>>>>>>>ModbusEZ4.rar.zip
    Since most VFD's are capable of supplying some useful info such as Volts, Amps, VFD temperature....etc, I will be adding a read command to plugin. If you create a simple text field on your UCCNC screen the plugin will write to this field the info of your choice. This will be completed as soon as my time allows.
    Updated VFD settings list:
    New MODBUSEZ SetUp Plugin For UCCNC-kcly-koc100-jpg KCLY KOC100
    New MODBUSEZ SetUp Plugin For UCCNC-machtric-s800e-jpg MACHTRIC S800E
    New MODBUSEZ SetUp Plugin For UCCNC-hitachi-x200-jpg Hitachi X200
    New MODBUSEZ SetUp Plugin For UCCNC-nowforever-e100-jpg NOWFOREVER E100
  5. #41
    Apr 2013
    Sweden
    Default Re: UPDATED MODBUSEZ4 Plugin
    Still crashing, even ModbusEZ4.
    I know why.
    I solved it, after which it was working for me.
    Others may get the same crash.
    I know how you could fix it.
    ...but you are not interested...
    ...so I don't care. This was my last test and probably the last post in this thread on this subject.
  6. #42
    Mar 2010
    America
    If anybody using this plugin have an issue please post or PM and I will help resolve the issue just like I've done in the past with the HYplugin that many are using.
    Dan
