New MODBUSEZ SetUp Plugin For UCCNC - Page 10
Page 10 of 10 FirstFirst ... 78910
Results 181 to 190 of 190
Thread: New MODBUSEZ SetUp Plugin For UCCNC
  1. #181
    Member PalleJensen's Avatar
    Nov 2020
    Default Re: New MODBUSEZ SetUp Plugin For UCCNC
    Quote Originally Posted by ger21 View Post
    I think this is the latest version.
    http://www.forum.cncdrive.com/download/file.php?id=648
    All the versions should be in this thread.
    forum.cncdrive.com • View topic - MODBUSEZ Plugin
    Perfect, Thanks a lot Gerry
  2. #182
    Apr 2016
    Hello I read your Modbusez post Dec 23 2020 I would be very very interested in your findings on the GT-Series I have one that demand to spin(lol) mine is a GT-7R5G-2, I am taken to your words if you can help me that whold be very greatfull.thank you in advance andyjack38
  3. #183
    Member Leefordplane's Avatar
    Mar 2021
    Can i use this plugin in mach3?
  4. #184
    Mar 2021
    Can i use this plugin in mach3? I have yl620-a vfd
  5. #185
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    No, it's for UCCNC only.
    Mach3 has a modbus plugin that will do the same thing.
    UCCNC 2017 Screenset
  6. #186
    Member MrHotwire's Avatar
    Jun 2019
    Care to share your setup? I am trying to get my Fuling DZB280 running, and I cannot find anything on it in regards to the Plugin Setup.
  7. #187
    did you manage to solve this problem ?
  8. #188
    Jun 2005
    Dont know if anyone monitors this thread nowadays, I have a Fuling dbz300 which is running via modbusez. the issue is that when 10000rpm is commanded in mdi the spindle only spins at 7500rpm. this is across the range of rpm. If I want 24000rpm I have to input 36000into UCCNC.
    It seem like a multiplier or conversion factor within the Modbusez pluging. the VFD shows the correct rpm the spindle is turning at, IE 36000rpm UCCNC 24000 indicated at the vfd.
    Any Ideas anyone?
    other than tis issue modbusez works really well, Thanks for your effort Dan.
    Phil
  9. #189
    Jun 2005
    sorry double post
    Phil
    tarnish1
  10. #190
    Apr 2023
    Hi Dan
    Awesome plugin ! Could you maybe share the source code?
    If not could you maybe make a new version with more fields "Amp Displays" to read more stuff from vfd like power, speed, amp, ......
  11. #191
    Follett71's Avatar
    May 2021
    I have a huanyang hy02d223b vfd and i've been having trouble with hyplugin wannt to try this, but i have no idea how to setup the modbus setup. any help out there? I know its an old thread
    thanks
