Need Help! Reset Error
Results 1 to 18 of 18
Thread: Reset Error
    Jul 2007
    Default Reset Error
    Now that I've got my software running properly, I've stumbled another issue. When the software boots up it the reset button is flashing and I get a message that a limit switch is triggered or an e stop has been pressed. The thing is I've checked my proximity sensors, they all are working properly and none are trigged when this error comes up. I don't have an E stop set up yet either, I've even removed the pin I've assigned it to in the software until everything is running. When I look at the diagnostics page it indicates that a hard limit has been triggered, although I'm not sure how. I've tried setting the limits as active high and low but that doesn't help. I can see the virtual LEDs turning on or off when I manually trigger a limit switch, so I assume that everything else is working properly. Reset Error-screenshot-uccnc-diagnostic-1-jpg
    Has anyone dealt with this before or have any ideas of what else I should test to troubleshoot this?
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: Reset Error
    I am not familiar with UCCNC, but I suspect this is a safety feature. After power-up the machine stays in e-stop mode until the operator deliberately resets it.
    Jun 2015
    Sweden
    change your X limit +, Y limit +, C limit +, X limit -, Z limit -, Z limit -, C limit - Active low settings, because it's clear that these are active now.
    Jul 2007
    I get this message when I try to reset the machine
    Reset Error-screenshot-error-jpg
    When I set the limits to active low, I can see that the LED's are off on the screen, but I get the same error.
    Jun 2015
    Sweden
    Can you make a printscreen of the disgnostics page.
    And by the way you are in demo mode.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Inputs that are correct with the UC300 running may be opposite in demo mode, which can cause the error.
    UCCNC 2017 Screenset
  7. #7
    Jul 2007
    Quote Originally Posted by OlfCNC View Post
    That printscreen was before I got the licensing issue sorted out, but it's the exact same error running the full version.
  8. #8
    Jul 2007
    I will grab another print screen with inputs set at active low when I can get back to my shop.
  9. #9
    Mar 2003
    Shelby Township
    Set your Estop port and pin to 0, Apply, and Save.
    Your E-Stop setup is not working correctly. You may need to toggle the active low setting before setting the port and pin, because it won't let you when the estop input is triggered.
  10. #10
    Jul 2007
    Quote Originally Posted by ger21 View Post
    Ive already set the e stop pin and port to 0 but I don't think I tried setting it active low as well. I'll give that a shot and hopefully have some luck with it.
  11. #11
    Jun 2015
    Sweden
    The message indicates that your limits or e-stop input is activated.
    I suggest you check the diagnostics page and I'm sure if all the limits and e-stop LEDs are off then you can remove the Reset but first you will have to configure them properly to make all of them go off.
  12. #12
    Jun 2016
    Quote Originally Posted by Andrew22 View Post
    If you are not using axis A, B or C uncheck "Axis Enabled".
  13. #13
    Jul 2007
    Quote Originally Posted by CT63 View Post
    I have two servos driving my x axis, so I have set up the A axis as a slave.
  14. #14
    Jul 2007
    I've tried setting all of the limit switches to active low again, but that's not doing anything for me either. Here's a print screen
    Reset Error-screenshot-uccnc-diagnostic-2-jpg
    Any ideas what else could be triggering a hard limit?
  15. #15
    Mar 2003
    Shelby Township
    Set the port and pin numbers to 0 for all of your limits and estops.
    At that point, you should be able to come out of estop.
    Once you do, then start setting things up one at a time, making sure each one is working correctly.
    Do NOT set anything up in demo mode. Make sure your UC300 is running, and connected.
    Setting up UCCNC in demo mode can result in a lot of settings that are incorrect, and don't show up until the motion controller is connected.
  16. #16
    Jul 2007
    So this problem has some how gone away on its own. While it's a relief that things are working now, it sucks that I don't really know what fixed it. I always try to understand a problem so I can learn for next time, but it seems like swearing at the computer and waiting a while paid off this time.
  17. #17
    Mar 2003
    Shelby Township
    As I mentioned before, I suspect that you were seeing the difference between demo mode, and with the UC300 connected.
  18. #18
    Jul 2007
    It would be great if that were the case, but I'm pretty sure I had resolved the issues with the license before this became a problem. I've been emailing back and forth with Balazs, and he's been extremely helpful working out kinks. An auto update of the firmware fixed my licensing problem I was having earlier, so maybe something in the background updated and worked itself out. Part of me thinks it may be because I'm using an old laptop with Vista, but whatever happened, it works. I've tried to replicate the problem on a separate computer that only has a demo of UCCNC installed and the reset always works. I'm pretty sure whatever caused that hard limit to trigger was what was giving me problems, and I don't know if that could be software alone.
    Now that the machine is running, I have found that I can trigger the hard limit by jogging over an end stop, and I'll get the same error I was seeing earlier. At least this time I just need to override and jog back and everything resets fine. I've set soft limits but jogging seems to ignore them. There's still a bunch of fine tuning that I need to do for calibration so I'm optimistic all will work out in the end.
Reset Error
Reset Error
