Success! Thanks for contributing and supporting this extremely useful plugin; especially with no compensation. We all owe you Dan!
Now I can commence fine tuning the installation and tackling the god awful EMI from the Huan Yang
Hi paulcc,
I use and tested 2017 screenset with all versions but what I forgot I did and failed to mention is causing this confusion. ops:
You need to change the RPM field number in screen edit in 2017 screen set to 2451.
Use HY12, and using 2017 screenset go to screen edit and click on the RPM field and change number to 2451 and you will be good to go.
Sorry,
Dan
EDIT:
Actually I didn't fail to mention, check post #307 in this thread. I will add it to manual though.
Hi Dan,
I agree with Paul, you are awesome!
The plugin works like a charm.
A very happy HY12 user here.
Regards, Jack.
In theory, there is no difference between theory and practice. But, in practice, there is.
Thank you for the kind words Jack and Paulcc, I written this plugin for myself and very happy to share it. I been visiting this site for many years and been helped countless times by members and it makes be happy to finally be able to give a little back.
Dan
Hi Dan, I wouldn't call that a little contribution, though!
Kind regards, Jack.
How can I setup the "Sact Labelnumber" in HY12? In HY10, this setting did exist.
The field number on the screen needs to be 2451.
UCCNC 2017 Screenset
Thank you for your quick reply ger21,
but there is no entity named "field number". Maybe, you mean "labelnumber"? If I change the labelnumber for Sact from 870 to 2451, the spindle does not start.
What do I have to do to show the Sact field the current spindle rotation value?
Without making any changes to the screen, you should be seeing the rpm in the "overridden" field that was added to UCCNC. That's why Dan changed the plugin.
Hi Nema,
You can set your Sact field to 2451 just as Ger21 posted.
Reason your spindle isn't starting is you must have other plugins loading and VFD missing it's set frequency. If you click the plus button on spindle override or set a frequency the plugin will start working properly and you won't have to do this procedure again next time it loads. Even if you have other plugins loading.
This happens on first setups or when another plugin is newly enabled. You can have as many plugins enabled as you like, but when first enabling it you need to go through this procedure once with the HYplugin. Been really busy and haven't had a chance to debug the cause of this.
Dan
Hi Nema,
You are the second person to report this. The only reason I knew of a work around is I spent a lot of time with the first trying to get him up and running, it wasn't until he installed a serial monitor I was able to see a frequency wasn't set.
Once he did the same as I suggested to you the plugin started working fine and he hasn't experienced this again, even after enabling and disabling other plugins. I haven't been able to reproduce this. It's really tough to debug a problem I cannot reproduce and very little details of those who have.
Dan
No problem Dan, I can live with this workaround. Your plugin is wonderful, it helps us UCCNC users a lot!
A more serious problem ist that UCCNC (which I like very much) comes out with new releases every few weeks. So I always have to set it up again (axxis, spindle, general, IO, plugins etc.) while overwriting the config file with a fresh one is recommended by the setup procedure. Then, testing if plugins and stuff still work. If not, fallback to the previous working version via backup. I still will do this for a while, then I will stay with the current working state and leave it how it is. Like most of us, I only use the basic functions (which work great) and am not interested in new xyzblabla stuff. Just my 2 or 3 cent.
They come out with new releases with every few months only.
Maybe you talking about their beta/test releases posted on the forum, those are more frequent.
I did upgrade my machine a few times, never overwritten the profile and it always worked without issues.
You might misunderstood the setup instructions. it only says that profile overwrite is recommended when skipping a major version of the software, not always.
The instructions copied for you:
Migrating from version 1.0xxx to 1.1xxx, 1.0xxx to 1.2xxx or 1.1xxx to 1.2xxx
Using an older major-version machine profile with a newer major software version is not recommended, we advice to create a new machine profile with the new major-version release when starting the work with the new software version. Also because there are many differences between the different major-versions of the software we advice to first install the new version into a different folder on the computer keeping the old version alive until the new version will be setup and running.
Then stick with the version on their website. Once you start using a test version, you kinda need to keep updating them until it's a full release.Like most of us, I only use the basic functions (which work great) and am not interested in new xyzblabla stuff. Just my 2 or 3 cent.
A little tip. Don't use the default profile, create a new one. Then when you install a new version, you're settings won't change.
I understand your frustration... that's what I also felt initially.
The way I am doing installations now is that every time I want to install a new release I just install it in a new, empty folder, which gives a default installation, but I don't start UCCNC at this moment. After installation I copy the Defaultscreenset.ssf file from the Screens, the Default.pro file and the whole Macro_Default folder contents from the Profiles folder as well as the contents of my own screen bitmap files from the previous installation and paste them into the same folders in the new installation, overwriting the default installation with these. Of course, also the UCCNClicense_XXXXXX.txt file is necessary to copy into the newly installed folder otherwise UCCNC will start in demo mode only.
It takes about a minute to do it, so I am no longer frustrated, however, I agree that an automatic import of settings should be included in the installation options. It should be pretty easy to implement, and add as an option, or if there would be compatibility issues because of major release change, it could just reject the import with a message to the user. Anyway, for now, there is no need to configure every time, just once and the following of what I am doing after that.
https://www.youtube.com/c/AdaptingCamera/videos
https://adapting-camera.blogspot.com
Not necessarily. If a new test release does not contain anything I am interested in I won't install it. If the next, or a later test release contains something I need or want then I install it. Skipping a test release is not an issue, next installation will of course contain everything since the last installation, but you really don't need to keep on installing every one every time a new is released. Every release is a full release, with a few exception, when only the UCCNC.exe is changed and in that case you just replace the previous one with the new one.
I am using the UCCNC 2017 screen set and am trying to get the HY12 plugin to work. Currently, when I press the M3 button on UCCNC, the RPM stops flashing on the VFD but nothing happens.
-I do not have any other plugins running.
-I have the COM port and baud rate set according to what is displayed in the device manager
-I have double verified that all the settings are correct in the VFD
-The RPM id has been changed from 870 to 2451
-A macroloop has been set to 1092 (edit - I just noticed that there is an M1092 file. Does this need to be added to the macro folder? I am assuming that I need to change all of the COM settings in that file to the COM port that I am actually using?)
-PWM is checked in the spindle settings
-Pulleys is unchecked
-The plugin has been configured while in the 2017 screenset
-The HY12.dll file is in the plugin folder
Am I missing any troubleshooting? Thanks for the help!
Hi nates02gt,
HY12 does not require any macro's. Please try when UCCNC loads....set a frequency/RPM or press the plus sign for spindle override, than press M3 button. If spindle starts and plugin starts working properly please report back.
Also make sure "call startup" and Enabled is checked in UCCNC plugin configure
Thanks,
Dan
