Huanyang VFD Macro/ Plugin - Page 31
Page 31 of 31 FirstFirst ... 2128293031
Results 361 to 370 of 370
Thread: Huanyang VFD Macro/ Plugin
  1. #361
    Mar 2010
    America
    Default Re: Huanyang VFD Macro/ Plugin
    Quote Originally Posted by nates02gt View Post
    Dan,
    Thanks for the quick reply! I do not see a way to set a frequency or override a frequency with the 2017 screenset. I did set the min speed to 8k as you suggested in an earlier post.
    Nate
    Sorry, what I meant by setting a frequency is change the RPM. The plugin will covert this to a frequency and send to your HY VFD.
    Below is a pic of the slide bar used for spindle override.
    Huanyang VFD Macro/ Plugin-2017-override-jpg
  2. #362
    Mar 2013
    Am I missing any troubleshooting? Thanks for the help!
    I was having the same problem yesterday.
    Biggest mistake was UCCNC version. I was 1.2037.
    Upgraded to 041, and got my copy of default profile working. Works like a charm.
    My 2017 profile doesn't. I'm sure I bungled it up trying to get it to work last night.
    However, a fresh install of 2017, and then a profile copied from the working profile still will not start the spindle. I'm done for the day, but watching with interest....
  3. #363
    Mar 2010
    America
    Quote Originally Posted by S1nned View Post
    With 2017 screenset you must go to screen edit and change the RPM field label # from 870 to 2451.
    Also you need to go back to HY12 configure and set up plugin per instructions like you did for default screen. The HY12 plugin saves it's settings in .pro file of profile being used. You will need to do this for any new profile created.
    Dan
  4. #364
    Mar 2016
    I had played with that slider a bit and nothing happened. I am using v1.0239 UCCNC and HY12.
    Quote Originally Posted by Dan911 View Post
  5. #365
    Mar 2016
    I checked the RPM setting again and it had reverted back to 870. I changed it to 2451 and then was able to get the spindle to turn on. It would not change speed though and I had to use the STOP button on the VFD to turn it off. After that I was not able to get the spindle to turn on through UCCNC. I restarted UCCNC as well as the computer. Each time I restart UCCNC, the RPM setting reverts back to 870. I pressed the Apply settings buttons as well as the Save Settings button in the Settings tab. I reprogrammed the VFD to use the controls on the VFD for now.
  6. #366
    Mar 2013
    I went out to check mine, again, because i know i set both of those. However, this is the first time I've messed with this, and was doing it wrong. After changing the RPM field to 2451 and clicking apply, i was unaware that the correct way to save the the setting was on the file tab in the editor. After changing it 4 times and it not taking effect, I dug a little deeper and figured it out. thanks for your patience and help, and most of all, making this plugin in the first place.
    All i had to do was make sure I hit the "Save Screenset" button on the file tab after editing the labelnumber field to 2451.
    Attached Thumbnails Attached Thumbnails Huanyang VFD Macro/ Plugin-save-png
  7. #367
    Mar 2013
    Nate, ive opened and closed UCCNC 4 or 5 times now, and it continues to work. I think we were having the same issue. See my post above, and i hope it works for you.
  8. #368
    Mar 2010
    America
    Sorry guys. I removed this from instructions since it was no longer needed for default screen. I will post new setup instructions that will include setup for 2017 screenset.
    use this for now for 2017 screenset:
    11. Goto CONFIGURATION / GENERAL SETTINGS / Edit screen. Go to your run screen (Shift + run), click on your on RPM field, choose "Selection tab"
    and change the labelnumber from "870" to 2451, than click apply settings, click on File tab on top of window and click "Save screenset".
  9. #369
    Mar 2016
    The curious thing now is that since I got the spindle to turn on through UCCNC that one time and ended up having to turn it off with the STOP button on the VFD, the display on the VFD does not stop flashing any longer when I press the M3 button on the UCCNC screen set. I tried using different USB ports and changing the COM settings each time and that did not make any difference. The good news is that the '2451' setting is staying set now.
  10. #370
    Mar 2010
    America
    Anytime you make a change in the HY12 configuration UCCNC needs to be shut down and restarted so settings could be saved and read on start up.
    The Huanyang VFD will continue to flash until spindle is turned on, this will also depend on what you have VFD set to display. If you are still having trouble connecting to VFD upload your .pro file and I will have a look to confirm your settings.
    Dan
