Huanyang VFD Macro/ Plugin - Page 12
Page 12 of 12 FirstFirst ... 29101112
Results 133 to 138 of 138
Thread: Huanyang VFD Macro/ Plugin
  1. #133
    Mar 2010
    America
    Default Re: Huanyang VFD Macro/ Plugin
    Thanks! Sent
  2. #134
    Mar 2003
    Tested, and replied.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  3. #135
    Mar 2010
    Thought I would provide an update. I am now up an running with the 95 plugin.
    Somewhere between the last time I used my router and when I added the UC300ETH-5LPT and UCCNC my RS-485 converter died. I replaced that component and everything is working just fine.
    Thanks,
    Bob
  4. #136
    Mar 2003
    Dan just sent me a new version to test, and I'm going out to the garage right now.
  5. #137
    Mar 2010
    America
    Quote Originally Posted by bhouin View Post
    Thanks,
    Bob
    Happy to hear your up and running and thanks for the update.
    Dan
  6. #138
    Mar 2010
    America
    Thank you Ger, your testing was a tremendous help and you lead me to the root of the problem. Once neither window displayed it had to be in the initializing and where I found problem. Funny thing is I was reading an article/debate on best way to initialize variables, definition, constructor, or method. The constructor is what I use and in the pro's it showed a slight speed advantage and 1 of the cons is exactly what I did...lol
    It all makes sense now why it worked on some comps and not others and had nothing to do with OS. You must have never set up your Ampfield in HY6 so this was never saved to the settings XML. Anyone who tried to use this new version would of problems, but it's why I didn't see it or anyone who tested hy6.
    Dan
