Huanyang VFD Macro/ Plugin - Page 11
Page 11 of 32 FirstFirst ... 89101112131421 ... LastLast
Results 121 to 132 of 376
Thread: Huanyang VFD Macro/ Plugin
  1. #121
    Mar 2010
    America
    Default Re: Huanyang VFD Macro/ Plugin
    Thank you for details/help. Fortunately for me i was able to immediately determine last night what my very stupid problem was once I looked at code. The message box is in a static method being called from another class in static method. The connection window is the problem.
    I test on Windows 8.1 64 bit with serial port monitor but disable window because that comp isn't connected to VFD, than bring to machine comp(win xp) and actually test how it functions. Surprisingly Windows XP 32 bit didn't care about this error and plugin worked perfectly. Once I forced messagebox window to display on win 8.1(it didn't) I was able to see the problem you're experiencing.
    I'm off to work now and will clean this up and repost tonight when I get home.
    Thanks for your help,
    Dan
  2. #122
    Mar 2003
    I should have added that I'm using Windows 10 Pro, x64.
    Glad you found it.
    I have a wedding to go to today, so can't do anything until tomorrow anyway.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  3. #123
    Mar 2010
    I did some checking and did do the PWM check box with apply and save again. Still no motion on the spindle.
    I took some screen shots to see if that would help in the troubleshooting.
    See attached PDF.
    Thanks again for all of the help
    Regards,
    Bob
    Attached Thumbnails Attached Thumbnails Huanyang VFD Macro/ Plugin-current_settings_rjh-pdf
  4. #124
    Mar 2003
    As I said last night, version 1.00097 is broken. Try using the 95 or 96 versions.
    When you start UCCNC, you should see a pop up window saying the VFD is connected. If you don't get this window, it won't work.
  5. #125
    Mar 2010
    I installed 95 with no change.
    Interesting, I wasn't aware of a pop-up. I am not getting any pop-up on startup of UCCNC. I am wondering if I should uninstall and reinstall everything.
  6. #126
    Mar 2003
    Did you go into the plugin and reconfigure it:
    In the plugin, when you click "Press for available Ports", does it find your port?
    And are you clicking both the save port, and save settings (calibrate in older version)?
    Then restart UCCNC.
    Did you change the VFD settings as stated in the .txt file. There are 5 or 6 VFD settings that you have to change.
    If you're not getting a popup window as soon as UCCNC starts, then the plugin is not setup right, or not communicating with the VFD.
  7. #127
    Mar 2010
    Gerry,
    When I configured the plugin earlier it did find the port when I clicked available ports. It matches what I expected to see. These were saved and then UCCNC restarted. I had also verified all of the pid settings outlined in the document with my VFD and everything was appropriate.
    Regards,
    Bob
  8. #128
    Mar 2010
    America
    Quote Originally Posted by bhouin View Post
    Gerry,
    Regards,
    Bob
    Hey Bhouin sorry for your troubles, all settings look good other than your using HY97 that I recently discovered had a problem thanks to you and ger21. I didn't get a chance to fix yet and you should use HY95 like ger21 suggested and is for now the latest recommended version.
    Follow the step by step in setup instructions in HY95 zip file and you shouldn't have a problem.
    Dan
  9. #129
    Mar 2003
    What are you using for the RS-485 connection? Are you sure that it's wired correctly?
  10. #130
    Mar 2010
    America
    Sorry missed this 1.
    Since you posted in your background you were controlling your Huanyang VFD with a RS485 connection in Mach3 I'm assuming you have that setup correctly. I'm also assuming you're using a typical China spindle 400hz/24000 rpm by settings you posted.
    What Huanyang plugin were you using for connection with Mach3? The Le royaume Huanyang plugin you had a choice for VFD address in the Huanyang VFD settings (PD163), this setting needs to be 1. Yes, you should get a "Connected" window on start up like ger21 already pointed out, make sure this window isn't buried behind other windows because the plugin won't start until you hit ok. If you close UCCNC you will never see this window.
    Dan
  11. #131
    Mar 2010
    America
    Hi Gerry, would you mind if I emailed you HYPLUGIN with the connection window fixed?
    I just cut a part and know it's working well but don't have your screenset loaded in machine comp yet, it has a old version of Win XP and plan on updating OP than will install, but didn't get around to it yet. I want to make sure all working good on that end.
    Dan
  12. #132
    Mar 2003
    Yeah, that's fine. Send it over and I'll go out and test it.
    I'm going to create a new profile from scratch to make sure It's set up properly.
