Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > TurboCAD/CAM
TurboCAD/CAM Discuss TurboCAD/CAM software here.
Old 04-02-2005, 08:49 AM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
Can't see lines
I'm using TurboCad 7.0 and all of the sudden I san't see the lines I draw. Black is the selected line color.
I can take a drawing I have created in the past and modify the lines and shapes but can't add to it.
HELP
Hager
Old 04-02-2005, 09:10 AM
kong is on a distinguished road
Sounds strange, did you try to re-install the program? Alternatively, uninstall, delete the TC folder, then re-install. This should clear it. I know you shouldn't have to though!
Old 04-02-2005, 09:11 AM
Mr.Chips's Avatar
Gold Member
Thanks Kong,
I'll wait a while to see if there is a quicker fix,
Hager
Old 04-02-2005, 09:15 AM
Right then, simple things to check in the meantime -
Make sure you are working on a visible layer
Make sure line style is set to continuous
Erm, I am scratching around now, but make sure no snaps are active!
I would be interested to know the solution when you find it!
Old 04-03-2005, 11:29 AM
Mr.Chips's Avatar
Gold Member
No Luck Kong.
I reinstalled and all is well.
Thanks for you'r tips though.
Hager
Need help extra lines in dxf carlnpa Mach Software (ArtSoft software) 3 03-19-2005 04:48 PM
Dirction / Step lines! bigal TurboCNC 2 02-06-2005 02:51 PM
How do I create solids from lines? HawainPand BobCad-Cam 2 09-12-2004 01:36 AM
forgoten how to erase lines in AutoCAD Apples Autodesk Software (Autocad, Inventor etc) 5 05-04-2004 10:06 AM
Lines and Joining them scottsss Rhino 3D 5 07-29-2003 06:41 AM
