Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > TurboCAD/CAM
TurboCAD/CAM Discuss TurboCAD/CAM software here.
Old 03-11-2009, 12:40 PM
ynnek's Avatar
ynnek is on a distinguished road
Offset Chain Milling vs Path Milling
What are the differneces between the two in TurboCAD/CAM. When I create my drawing & do my cam fucntions, the preview does not seem to show my offset. I may be doing something wrong.
Old 03-11-2009, 06:29 PM
cmnewcomer is on a distinguished road
ynnek,
I'm no expert but the Chain-Offset milling feature will offset the cutter from the drawn path by the amount set in Stepover Amount dialogue. This can be changed in the Setup option or the View Operation Properties window. When you select the object, it should show an arrow with a circle the size of the chosen tool. Make sure it is on the correct side of the line that you want to offset from!
I'm pretty sure that Path milling will not offset and simply follows the drawing path.
Best Regards.
Carl
Need Help!- NPT Milling jybute Haas Mills 11 08-14-2008 03:19 PM
Milling with bottom vs milling with side? REVCAM_Bob CNCzone Club House 13 06-30-2008 10:23 AM
Need Help!- v22 CAM: Control direction of milling path tikka308 BobCad-Cam 2 03-09-2008 10:49 AM
TurboCadCam and Offset Chain Milling philbur TurboCAD/CAM 0 02-05-2007 05:05 PM
Milling a PCB Ayjay General Electronics Discussion 3 05-20-2006 12:01 AM
