| TurboCAD/CAM Discuss TurboCAD/CAM software here. |
#13
I can't let this go unanswered any longer, because mics_54 suggests that you shouldn't do what works, but doesn't offer a different method. In fact, it is exactly what you want to do. I routinely build parts by cutting up circles and other things, then joining all of the separate lines into one closed polyline, then selecting it and specifying a thickness. It is the same as using simple extrude, but much faster to just select and type a thickness value. If you can get your 3D model created by whatever means you can think of, go for it. Regards, - Just Gary |
#14
| It depends on what he is making "thicker". Is he makeing the lines thicker? If hes just specifying line thickness or width does it really create a 3D object...is it a surface object..is it a solid? I don't know...maybe you know. I don't know because he didn't really say what he was doing. If what he is doing works...why ask the question? I will disable the notification on this thread so it doesnt send me an email anymore. I gave the best advice I know which is to post the question in a forum specific to the software and it's version. He can post the file and get an answer in a few hours unlike a week it takes here. |
#15
| hi from the uk just put up a freebie trial website with some turbocad stuff if wan,t a look it,s (all lower case) www.smgdesign.net type in top browser @ http will get you straight there BEST REGARDS STUGOD |
#16
I gave up on turbocam and use rhinocam save my tcad drawings as dxf,s and it works fine in rhino here is my turbocad blog and website http://stugods3dblog.blogspot.com/ http://smgdesign.net/ |
| Tags |
| node, nodes, turbo cad, turbocad |
| Carbon Sheets | barkster | Parts for Radio Control Models | 4 | 11-03-2008 06:03 AM |
| Cheat sheets.... | KaesynCAM_Tech | Mori lathes | 3 | 09-30-2008 09:47 AM |
| Need Help!- converting imported part drawing to mold drawing | msomerville | BobCad-Cam | 6 | 08-29-2008 06:56 AM |
| Material Safety Data Sheets (MSDS) | widgitmaster | Polls | 7 | 08-08-2006 04:38 PM |
| TurboCad Drawing | Hack | TurboCAD/CAM | 4 | 01-11-2005 05:18 PM |
