Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > TurboCAD/CAM
TurboCAD/CAM Discuss TurboCAD/CAM software here.
Old 04-28-2003, 05:50 PM
handersen is on a distinguished road
Printing with TurboCAD
Hi all,
Why does TurboCAD print out my drawings larger than drawn? Like a 4.5" distance is printing at 4.7". Thanks
Old 04-28-2003, 11:41 PM
HomeCNC's Avatar
HomeCNC is on a distinguished road
Printing is very different than plotting. When printing, look at the properties in the printer control window. Look for a scale setting. My guess is you are set to 'Fit to paper size' and you should be set to 100%.
Jeff Davis (HomeCNC)
http://www.homecnc.info
Old 05-18-2003, 04:28 PM
jemmyell is on a distinguished road
Is anybody aware of a utility for converting the AutoCAD style 'stick' fonts that come with TurboCAD and AutoCAD? I would like to turn them into TrueType fonts for use with DeskEngrave and VectorCAD
James Leonard - www.DragonCNC.com - www.LeonardCNCSoftware.com - www.CorelDRAWCadCam.com - www.LeonardMusicalInstruments.com
Old 06-17-2003, 05:17 PM
mauritz is on a distinguished road
TurboCAD uses the "stick type fonts" to be compatible with AutoCAD drawings. You also have an option in TurboCAD to use True Type fonts installed on your PC.
Mauritz
Turbocad solid modeller? kong TurboCAD/CAM 1 11-06-2011 07:28 PM
TurboCad 6 vs 10.2 with Ace Converter goodeye TurboCAD/CAM 7 11-27-2007 03:59 PM
desk engrave and turbocad ljoe1969 TurboCAD/CAM 6 04-08-2005 01:04 AM
pcboards and screen printing lurch General Electronics Discussion 1 10-17-2004 02:40 AM
TurboCad 9. to G-code = ??? camfambmw5 TurboCAD/CAM 3 11-30-2003 12:07 PM
