Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > TurboCAD/CAM
TurboCAD/CAM Discuss TurboCAD/CAM software here.
Old 03-14-2007, 08:06 PM
servoencoder is on a distinguished road
TurboCAD and Mach3
I have been designing a 3-axis 2.5D mill for some time now and the software has been troubling me quite a bit. The conversion from turbocad's (v7 or v12) .dxf and sometimes .plt files formats are not accepted by mach 3 - the g-code will only will be bout 10 lines long.
Also 3d plt drawings will transfer into mach 3 only as flat drawings, this is similar to what a friend is expirenceing.
Dan
Old 03-14-2007, 08:11 PM
ger21's Avatar
Mach3 can only convert 2D flat drawings, not 3D. If you can post a problem .dxf I'll take a look at it.
What version of Mach3? Are you using LazyCAM?
Old 03-14-2007, 08:48 PM
I have attached a simple text drawing, I am using v 1.83.027 mach3, and never seen lazycam.
This mach3 was given to me to try out and what's got me interested in CNC.
well I'd prefer to use the software i'd already have but maybe I can be steered towards something better here's what I have:
servo motors
turbocad - very accustomed to
would like 2.5 D milling with servo software feedback
altera fpga
Old 03-14-2007, 09:22 PM
ger21's Avatar
You can't convert text to g-code with most .dxf converters. I don't use TurboCAD, but you can try exploding the text, or maybe they have a tool to convert text to lines or polylines. Regular text won't work.
Newer versions of Mach3 no longer have the .dxf importer you're using. They have a basic CAM program called LazyCAM. You can download and try the newest version from www.machsupport.com Mach3 is free to use for up to 1000 lines of g-code, btw.
Old 03-14-2007, 09:24 PM
ger21's Avatar
One other thing, Mach3 can't do anything with servo feedback, other than possibly display actual position, if you modify the stock screens and add some VB script.
Old 06-07-2007, 10:26 AM
askman is on a distinguished road
well, turbocad font works fine if you explode it. if you set up your feature with layers. (different depth cut for different layer) you can use lazycam as 2.5d setup pretty easily.
Old 11-21-2007, 09:38 AM
blumpie is on a distinguished road
Actually, their web site now states 500 lines of code, however, in trial runs, I am only able to do 250.
Old 11-21-2007, 11:23 AM
ger21's Avatar
It was 1000 lines when I posted that. It's since changed to 500. You shouldn't be limited to 250 lines, though. Are you using subroutines maybe? Are you sure it's only doing 250? If it is, post the code and I'll look at it.
Old 11-21-2007, 04:49 PM
Thanks, but I have already deleted it. It was working kind of buggy anyway (Vista?) so I was not so pleased with it. I am getting the CAM plugin for Turbo Cad. Too bad it's only 2.5D, but it will be enough to start with.
MACH3 was doing more than 1000 lines of code with their demo files, but when I used LaxyCam, it would only export 250 lines. That was barley enough for one letter.
Old 11-21-2007, 07:13 PM
ger21's Avatar
LazyCAM now will export only 50 lines of code, unless you pay for the license for it.
  #11   Ban this user!
Old 11-22-2007, 02:16 PM
Right now, the CAM pugin for TurboCad seems ideal (I can get it for free).
I use TurboCad almost exlusivley for drawing, so it seems a logical choice.
I am using EMC2 for machine control and just got that working today. I dont have a wiring diagram for the motors, but they are working. I'm not sure if they are woring in the right direction however.............
I just hope that EMC will be able to read the gcode that TurboCAD/CAM produces.
I have enough electronics to build 2 machines; one small and one medium. I'm going to start on the small one first and I would be happy to get it to draw with a pencil.
I will then focus on the larger machine to do larger engravings and router work. I will probably need a true 3d gcode generator sometime in the future for carvings.
The main goal, and my reason for starting this project was to engrave on curved survaces (i.e. drums). I would buld the x axis as some sort of rotory table that will turn the drum as opposed to the traditional linear motion.
  #12   Ban this user!
Old 11-23-2007, 08:30 PM
motoboy's Avatar
motoboy is on a distinguished road
I'm buying the Tormach mill and I noticed I can get Turbocad Pro with the CAM plug-in for $495 with the machine. What is the difference between this and Turbocadcam 3.0 which can be bought on this site for $299?:
http://www.academicsuperstore.com/ma...p.html?PartNo=
Turbocad/cam marvinstov TurboCAD/CAM 23 09-24-2007 04:34 PM
TurboCad Pro 12 Gandalf TurboCAD/CAM 5 12-22-2006 11:39 AM
TurboCad Help.... IN-WondeR TurboCAD/CAM 0 06-22-2006 01:07 PM
Turbocad Prof. 11 & Mach3 & CAM ??? fidibus42 General CAM Discussion 10 01-08-2006 12:15 PM
Turbocad DXF help qsacracer TurboCAD/CAM 1 12-18-2004 03:22 AM
