| TurboCAD/CAM Discuss TurboCAD/CAM software here. |
#13
| Blumpie, I am considering getting the cam plugin for turbocad (I have until 1/31/8 to get it for $199). Have you had any luck with turbocad's cam plugin and EMC2? Thanks, Skip www.ShopFileR.com |
#14
| I use TurboCad/Cam (v12) with Mach3 for both my (mini/micro) lathe and mill. For the most part, I really like it. One of the best things is that the Drawing and Gcode setup are in the same file. The actual gcode is saved to a seperate file, but I don't have to convert the drawings to dxf like I do with partmaster. What I don't like about turbocad/cam are some of the paths it creates. It mills a LOT of air and on the lathe, it seems to cut curves backwards. Finding postprocessor setups for Mach3 Mill and Lathe was impossible. In the end, I just worked on them until I figured out what worked on each. Note: Turbocad/cam will not do an A axis. It only does 2.5d milling. It can not rotate a round object while it cuts. I use Partmaster for that and only that. I hate partmaster, but I needed a 4th axis. |
#15
| Thanks jmdelta! I will go ahead and order it this week. I just upgraded from Turbocad 10.2 to 14.2 so I guess I will go the whole route and save some $$$ while i am at it. Skip www.ShopFileR.com |
#16
| As a newbie to cnc I have been looking for cad program to go alond w/ my cnc bridgeport. If any body can advise me I would appreciate it. My goal is to draw my part and have it converted to G code for the Mach 3 Mill. I was thinking of using a flash drive to hold the programs. Vinnie |
#17
#18
i am using v 15 turning files into dxf,s and sending to rhino with rhino cam 2 plugin using in demo mode at the moment i got free prog simplycam from cnet(download.com) it,s real easy to use prog. it has a few simple images you can vectorize images edit the profiles i got the hang of it in acouple of hours. ps got a free trial website all lower case got some cool tcad stuff on cnc controler gas axe welder etc any way have a butchers www.smgdesign.net type in top browser at http will get u straight there |
#19
| jmdelta, You state that you are using TCC with Mach3 on both your lathe and mill. Care to share your machine setup info from TCC so we have a starting place to work from? I've just started, and I keep having to hand edit the code to make it work in Mach. |
| Turbocad/cam | marvinstov | TurboCAD/CAM | 23 | 09-24-2007 03:34 PM |
| TurboCad Pro 12 | Gandalf | TurboCAD/CAM | 5 | 12-22-2006 10:39 AM |
| TurboCad Help.... | IN-WondeR | TurboCAD/CAM | 0 | 06-22-2006 12:07 PM |
| Turbocad Prof. 11 & Mach3 & CAM ??? | fidibus42 | General CAM Discussion | 10 | 01-08-2006 11:15 AM |
| Turbocad DXF help | qsacracer | TurboCAD/CAM | 1 | 12-18-2004 02:22 AM |
