Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > TurboCAD/CAM
TurboCAD/CAM Discuss TurboCAD/CAM software here.
  #13   Ban this user!
Old 02-17-2004, 02:06 PM
freezer is on a distinguished road
Ok, that methood worked for layer 1 and 2 but layer 3 (cross and flames) i have redone 3 times and still not working... is there something different about layer 3 that is preventing the poly line?
  #14   Ban this user!
Old 02-17-2004, 02:57 PM
ok, played with it a bit more and found that i had a couple of lines that were not exactly connected... fixed that and now it works.
Thanks for the help!
Rod
how do i change pcnc software to english from german chris69randy DIY-CNC Router Table Machines 1 05-24-2005 02:35 PM
Quick change tool system (milling) mark c General Metal Working Machines 3 02-17-2005 06:50 AM
Adding a manual gear change call MILLMANM Post Processors for MC 5 01-04-2005 10:05 PM
Is there a default feed rate ? and if so can you change it? fyffe555 TurboCNC 0 02-08-2004 08:09 PM
Quick change head design kdoney DIY-CNC Router Table Machines 1 07-05-2003 11:57 AM
