Results 1 to 9 of 9
Thread: turbo cad/cam
    Jul 2006
    turbo cad/cam
    1) I am having trouble picking exact location of hole for drilling cam op. what am doing wrong?
    2) Is there any info on turbo cam plug-in, besides the tutorials on the disk?
    Jun 2006
    Stavanger, Norway
    Not sure if it's the right fix but try zooming in before you spot the hole center. Thats what I do.
    Regards
    Phil
    Quote Originally Posted by dxxx View Post
    Jan 2005
    Cool Try this
    If your part is a solid it may not always pick up the right center. The same goes if the hole was made using splines and such. To work around this you use the "draw circle by three points" tool and pick 3 vertice points on the hole. It will draw a circle that you can pick the center of.
    Jun 2011
    Hole Coordinates for TurboCad 14 Cam Plugin
    We are trying to set the hole within.0001 - I just went into the g codes and modifed the coordinates...there has got to be a better way...
    Mar 2009
    I've had similar issues. The snap control seemed to be the key. There is an option for snapping to the center of a circle which never seemed to work for me, until I realized that they want you to click on the circle, not the "Estimated center". That made all the difference. Good luck.
    Ken
    Registered ynnek's Avatar
    Apr 2008
    Quote Originally Posted by ksanalytical View Post
    Ken
    That is the ideal way to do this. Just make sure the "Snap To Cemter" is activated.
    Mar 2009
    I wonder if your space units might be set to a default of 2 decimal places. You can check under Options/Space Units/Precision. Mine defaults to 2 decimal places. Perhaps you're having a similar problem.
    Ken
    Apr 2008
    Set your precision to "10" in the Drawing Setup || Space Units tab. Then, in your TurboCAD/CAM drawing space, make sure to turn on the "Center" snap.
    Oct 2012
    Britain
    CAM 2D WITH TOOL SELECTION AND SIMULATIONS
    I got TurboCAD for £15. Where can a person get a version of CAM a bit like Alphacam from them; I know that they are a South African company. I have seen ContourCAM but i'm specificly after a 2D version.
  • Posting Permissions
