Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > TurboCAD/CAM
TurboCAD/CAM Discuss TurboCAD/CAM software here.
Old 04-23-2006, 09:49 AM
phil burman is on a distinguished road
TCC v3 - keeps inserting G28 - why
Hi Folks,
Some help would be most appreciated.
TCC v3 seems to add the following code between tool changes:
G91 G28 Z0. M09
G28 Y0.
Particularly the g28. At the moment I edit this out after generating the g code file. How else do I stop this happening. Have I missed something in "settings"?
Secondly it seems that I can't edit this code in the g code window. I can only edit the G code when a single operation is highlighted and then the offending code is not visible.
Any pointers in the right direction would be great.
Phil
Old 06-26-2006, 12:29 AM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Question G28
I am New to TurboCAD but not G-Code.
This G-Code is used to return an axis to the home position for tool change.
Ex. G91G28Z0M19
G91 Incremental Motion
G28 Home
Z0 Z postition Home for ATC
M19 Origin Spindle
Usually after a tool is finished being used one would send it home in the Z axis and sometimes Y and Z to change tools on some machines.
Is the TurbCad post sending a tool home before you are finished using it? Like maybe when you are doing a pocket in steps or set D.O.C.?
This may be a simple fix in the TurboCAD Post.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
