Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > TurboCAD/CAM
TurboCAD/CAM Discuss TurboCAD/CAM software here.
Old 10-13-2005, 10:56 AM
jc286006 is on a distinguished road
layers in a drawing
i am trying to cut some airplane parts in liteply i would like to be able to position the smaller parts inside the larger parts and be able to specify these to be cut first but i havent been able to figure out how to use the layer function to allow me to put these smaller parts on another layer so that i can specify them too be cut first when i convert the drawing to g-code with ace converter can someone give me some advise as to how to do this
thanks for any help you can give me
James
Old 10-13-2005, 11:20 AM
ger21's Avatar
Most CAD programs will let you select an object, pull up it's properties, and change the layer there. Or select the object, and just choose a new layer and it will switch. Or if neither of those work, change the layer before you draw them.
Old 10-13-2005, 01:10 PM
thanks gerry ill try your suggestions when i get home
Old 11-11-2005, 02:16 PM
rcazwillis is on a distinguished road
Did you figure this out. I had to do something similiar this morning.
In Ace, you can set priorities for each for each of the layers. I think it is a right click on the layer. Set the small part to priorty 1 and the large part to priorty 2. The g code should then be sequenced. I usually have to edit the code to make it do exactly what I want.
