Results 1 to 2 of 2
Thread: Huge circles or arcs.
    Nov 2010
    So what Im trying to do is make a rocker table in wood, what happens when I cut huge circles or arcs is they cut strait line like a hexigon. I know in cnc everything is a strait line or step in xyz. Small circles are fine in turbo cad.
    I guess if you draw a circle in turbo cad and zoom in you will see its just strait lines to make that circle, how do I change that Im making something thats 66 inches long. Thanks.
    Feb 2007
    This post has been here for a while and I hope you have already found a solution. I wonder if you could either node edit the arc to divide it into smaller portions. The easier way to accomplish the same thing would be to explode the arc several times to break up the arc. I have not tried this with anything I cut, but it might smooth out your lines.
    Duane
  1. Huge Problem with Turning Arcs HELP
    By Cartierusm in forum Dolphin CADCAM
    Last Post: 06-10-2009, 08:40 PM
  2. Cutting arcs and circles
    By inaman in forum GibbsCAM
    Last Post: 04-26-2008, 03:04 PM
  3. Huge Arcs HELP ?????
    By Biggermens in forum Mach Software (ArtSoft software)
    Last Post: 04-26-2007, 09:50 AM
  4. Huge Arcs
    By Biggermens in forum Mach Lathe
    Last Post: 04-23-2007, 11:49 AM
  5. Cutting circles and arcs
    By Hack in forum General Electronics Discussion
    Last Post: 11-08-2004, 04:12 PM
