Results 1 to 8 of 8
Thread: TurboCAD not Loading
    Mar 2010
    U.S.A.
    Hey there...
    I just thought I would see if anyone else has seen this problem, I had TurboCAD 17 on my PC running fine (I use it often to generate cut files for CNC plasma),
    Anyway, I went to open it and it just sat there and hung loading, I thought maybe an update would help, so I updated to 17.1 then 17.2 and it still hangs, I did notice that it looks like the thing that is hanging in the Internet pallet, I can see at the bottom of the screen it franticly trying to load something, this seems to just hang the application to the point it will not load.
    I tried uninstalling the application and re-installing it, when I did I was able to load TurboCAD just fine, but after I closed the app and tried to re-launch it, I got the same problem, hangs while loading.
    So I un-installed it again and re-installed it and it launched it again, and again it launched fine, so I set the internet pallet to load a blank page thinking that would solve the problem, but it did the same thing after I shut the app down and restarted it…
    I can’t seem to find any help on this issue, I was hoping that there may be some way to disable the internet pallet all together, but I can’t seem to find out how to.
    Anyone have any ideas?
    Mar 2010
    U.S.A.
    Someone said to update printer and video drivers, which I did and still have the same problem,
    Any Ideas?
    I'm stumped....
    Oct 2005
    HatchMan,
    Did you find/correct the problem with TurboCad hanging on loading.
    Harold
    Mar 2010
    U.S.A.
    Nope... I have not solved the problem... I figure I'm gonna have to format the hard drive and reinstall everything again, and hope that fixes the problem...
    Oct 2005
    When you did the uninstall, did you check to make sure that the config file had been removed. I don't think that the uninstall will remove the config of the previous install.
    The install creates two folders one in the Program Files and the other in the user documents file. The configl file will be in the user file. In the program files folder it will be listed as ISMI Design. The user file will be listed as user,(your name or user) documents, TurboCad 17 (or your ver. NO.) by defualt the config, backups and drawings are store here. In doing an uninstall the config file needs to be removed and let the install create and new one.
    I don't know is this will fix your problem, but worth a try.
    Harold
    Mar 2010
    U.S.A.
    Harold,
    I didn't try that, when I get home I will give that a try.
    It is for sure worth a try!
    Thanks for the lead, I will let you know if it worked
    Mar 2010
    U.S.A.
    Harold...
    Nope that didn't do it either... Ahhhhhhhh!!!!!!!!!!!!!!!! it's something stupid...
    Thanks for try...
    I think I will be formating the HDD and reinstalling everything and hope that does it.
    Oct 2005
    HatchMan,
    Sorry to hear that it didn't work. I was going to refer you to the TurboCad Fourms, but I see that you had already been there with no help.
    Regards
    Harold
    1. Need Help!- turbocad 16 +mdx 15
      By bigdaddy1962 in forum TurboCAD/CAM
      Last Post: 09-11-2010, 03:02 PM
    2. Turbocad for Mac
      By hoarp001 in forum General CAD Discussion
      Last Post: 09-26-2009, 05:12 PM
    3. Need Help!- Turbocad//cam v14
      By bob.mullikin in forum TurboCAD/CAM
      Last Post: 07-28-2009, 07:46 PM
    4. TurboCAD CAM
      By Paul Tracey in forum Product and Manufacturer Announcements
      Last Post: 01-27-2009, 07:39 AM
    5. Turbocad DXF help
      By qsacracer in forum TurboCAD/CAM
      Last Post: 12-18-2004, 03:22 AM
