I am looking for a way to design a cut for a sheet of material. The sheet would be bent along a curve, rotated a set number of degrees, and then trimmed along two planes. One parallel and one perpendicular to the original plane. The idea is to be able to take the resulting piece and pull the dimensions off of it to determine how to cut it from a flat piece of sheet.
LinkBack URL
About LinkBacks
