| TurboCAD/CAM Discuss TurboCAD/CAM software here. |
| I am using TCC 3 and Mach2, it was recommended to me. I'm new to CNC but it seems to work fine. I understand that Mach3 might still be a bit buggy for a newcomer so possibly you should start with Mach2. An upgrade later, when its fully sorted, to Mach3 is free. Regards Phil
Mach3 has far more features than Mach2, and must be configured from scratch, as the Mach2 .xml file (settings) is different than Mach3's and is not transferrable. So starting with Mach3 is the better choice IMO.
HI all I have turbo cadcam V3 I found it easy to learn great to draw with and to generate G Codes .you can pocket mill offset mill contour mill drill etc etc . you can edit the G Code befor you save it then go to Mach2/3 open as G Code and there it is and away you go complex curvrs and patterns no problems allway works every time Thank B Norris Australia .
__________________ Big Borris |
| probe with mach3 | Don C | Mach Software (ArtSoft software) | 1 | 01-05-2006 10:19 AM |
| A new feature in Mach3.... | ynneb | Mach Software (ArtSoft software) | 20 | 09-20-2005 06:53 PM |
| Mach3 Plasma | anthony | Mach Plasma / Laser | 1 | 05-18-2005 07:21 PM |
| Mach3 Splash Screen Design Competition | CNCadmin | Mach Software (ArtSoft software) | 120 | 04-01-2005 04:51 PM |
| Mach3 lathe questions | JFettig | Mach Lathe | 5 | 03-16-2005 06:43 PM |
