Results 1 to 6 of 6
Thread: how to clamp cylinderical part in 4 axis vmc without runout
    Sep 2010
    india
    Dear sir,
    I have facing problem against cylindrical part clamping in 4 axis rotary table in vmc. because now i had clamped with three jaw chuck ,but run out can't control with in 20 micron.I need solution for this problem.
    Apr 2004
    Oakland CA USA
    The three-jaw chuck is your problem
    It isn't going to hold things absolutely accurately; there's a certain amount of runout in even the best of them. If you need to hold this cylindrical part within 20 microns, you'll need to use a 4-jaw chuck and dial it in with a test dial indicator in that range. It will take longer, but get closer to what you want.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Quote Originally Posted by mskumar View Post
    Dear sir,
    Sep 2010
    india
    Dear sir,
    Thank for your suggestion,(use four jaw chuck for controlling run out) but i want to run production parts . so loading time 2 mints only can spend,so pl suggest any other way for quickly with repeatability clamping method .we are wasting time for clamping and adjusting run out in the part.
    Apr 2004
    Oakland CA USA
    It looks like you'll need a custom fixture, then
    If you spend the money, you can probably find someone who can fit a collet system into your rotary table, that would accurately hold your parts. It won't be cheap, though. You might post something in the Fixtures and Workholding forum to find someone to help you with this.
    Andrew Werby
    Registered neilw20's Avatar
    Jun 2007
    Add some smart software to the machine so it can find it's own zero with a probe, and compensate accordingly.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Oct 2005
    us
    Just buy a quality collet chuck for your 4th axis.
    20 microns is approximately .00078 inches. thats hard to hold in production unless you have a good quality collet chuck.
    Nate.
    Ann Arbor Meechigan
    1. Need Help!- Building Vacuum Clamp and Mechanical Clamp Sub-Table
      By automizer in forum DIY CNC Router Table Machines
      Last Post: 04-27-2012, 01:46 PM
    2. 1/8 Collet runout - or ruter runout
      By slavkok in forum Wood Working Tooling
      Last Post: 03-04-2010, 08:24 AM
    3. Need Help!- QC 30 Spindle Nut causing runout, part number/where to find?
      By shiver-91vr4 in forum Bridgeport and Hardinge Mills
      Last Post: 01-19-2010, 08:15 PM
    4. Need Help!- Building Vacuum Clamp and Mechanical Clamp Sub-Table
      By automizer in forum Work Fixtures and Hold-Down Solutions
      Last Post: 04-07-2008, 10:05 PM
    5. Please help me how to clamp this odd-shaped part in a lathe?
      By alarizp in forum General Metalwork Discussion
      Last Post: 09-03-2006, 11:02 PM
