Mdf 18mm cutting setting for 5 minutes
Results 1 to 2 of 2
Thread: Mdf 18mm cutting setting for 5 minutes
    Feb 2017
    Indonesia
    Default Mdf 18mm cutting setting for 5 minutes
    Hi my name is marcus, i'm new user of cnc router for mdf wood like this image, size 1.22m x 2.44m thickness 18mm, right now i'm using rpm 18.000, stepdown 4mm second, feedrate 15mm/second, too slow, only 4 piece a day, and the router bit easily to broke, so need help, here is my questions
    What is the setting for these? material thickness 18mm
    1. spindle rpm speed?
    2. Step down mm/second?
    3. Feedrate mm/second?
    4. what kind of Router bit ?
    Hope you can help me
    Thank you very much
    Attached Thumbnails Attached Thumbnails Mdf 18mm cutting setting for 5 minutes-cutting-list-png
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Mdf 18mm cutting setting for 5 minutes
    What kind of machine do you have?
    UCCNC 2017 Screenset
